help from the mac users
https://forums.aussieveedubbers.com/threads/49105/help-from-the-mac-users
barls ·
im occasionally getting a bad server reponse and then cant get on at all. im only on because im on the gfs laptop which is also a mac. id like to know if its my computer or something else
crewcabconnection ·
if you're using OSX, then you can 'ping' the sever. If you're using Safari, then try clearing the cache and reloading. If you're using IE, then stop it, your making me laugh.
You can also 'shift click' the URL which should force the connection. If you're using Airport then check the signal. Wireless picks up crap, and you might drop out. But Airport is pretty solid. If you're using Ethernet port on ADSL or cable, then should not be a hassle.
There's no obvious reason ... Do a google search for 'bandwidth speed test' and use a free speed tester to see what you're connection is like. It is entirely possible the line is crap, your splitter box is crap etc., you should be able to bench mark what you're getting with what you think you should be getting.
Telstra Cable can be shite in the wet ... You might need them to check the line.....if it's just this site, then it's hard to diagnose ... The server does load-balance well, so if you're getting a 500 Internal Server Error then it might be refusing connections, but I can't see that, AVD is very solid these days....as the Techies....
Sorry can't pin it down more...
Schmoburger ·
Are you using OSX?... I get a similar thing on my mac on occasion, which is usually fixed by simply clicking refresh.
Sometimes it goes out alltogether, which is usually my wireless broadband waves spacking out between the antenna and the base station 8kms away... but i assume you are only hVING THIS PROB WITH AVD correct? 🙂
Can't tell for sure what it is, but it seems connection related.
barls ·
ok i dont think its airport or the line as i can still get on to other sites. im using 10.4 and safari ill try the shift click one if not ill reset the cache again and restart. i never had this problem before upgrading
Schmoburger ·
Yeah.. as ccc said.. ditch IE if your using it... use safari.. or camino.
I also noticed safari do some spack things after upgrading to OS 10.3.9 last year... worked fine with 10.3.6...crap on a stick with .9...meh...luckily it was my dads PB that was the guineapig LOL...still comfy on 10.3.6 here.
what system you using?... Jag, Panther or Tiger, and what update version?
barls ·
the latest version of everything possible
Schmoburger ·
ok..just saw your post.... cant help much with tiger..but as i said... OSX updates often do more damage than what they fix. 🙁
barls ·
yeah i know ive already had the problem with installing 10.4. tried the shift click didnt work so i emptied the cache and restarted so we will see
Schmoburger ·
did you have a problem after upgrading to tiger from panther?... It is never reccomended that you use the "Upgrade" option... it always screws up...thats a given.
Instead.. I'd reccomend booting from CD/DVD and doin an "Archive and Instsall"
This will save your settings.. but install all new system files.
chances are it will get rid of a lot of issues, and generally run faster.
if you started with 10.4 when you purchased the machine... i can only reccomend reinstalling and stepping back one incremental update.
hope this might help.
barls ·
that wasnt the problem i had a dodgy hd which wouldnt let it boot. im back on mine now
vanderaj ·
The trick with dodgy upgrades from 10.4.0 -> 10.4.5 is that people should always fire up disk utility, and run "Repair Permissions" and see if the disk needs repairing by clicking "Verify Disk". I've done this every single time, and I've never had a upgrade screw up on me. And I do a lot of dev and have 720,000 files on my Mac.
On Barl's specific problem, I use Safari 2.0.3 (the version which comes with 10.4.5), and it's my main browser. It's not Safari's fault; I used Safari to develop this software, and I use Safari as my main browser. Therefore if it was a Safari issue with UltimaBB or our site, I would see it also. Therefore, it has to be Barl's gf's Mac or their connection.
NSURLErrorDomain -1011 errors used to pop up in 10.3.x when (pretty much all) sites didn't provide a content length field. It's not required by HTTP 1.1, so no one does the work to figure it out now unless you turn output buffering on, and even then, most web servers still don't provide it.
Try going to http://www.msnbc.msn.com/
If that also does the -1011 thing (mine shows the site fine), your browser needs updating to the latest.
thanks,
Andrew
Starbug ·
i vaguely remember a 10.3 update which made safari crap itself, it was fixed by repairing disk permissions and the preference file...
look up a program called 'preferential treatment' on the mac OSX software/apps section on the apple website, its what i used to help fix it last time safari had a woopsie.
barls ·
well im back on but i still have no idea what caused it. all i did in the end was empty the cache and reboot.
crewcabconnection ·
mmm, mac talk...
barls ·
crewcabconnection wrote:mmm, mac talk...
now if we can just include beer and vw ill be a happy chappy
