I'm rebuilding my kombi's 2L at the moment. It has no thermostat or pulley or cable. It has one flap in the fan housing, in the top outlet above the oil cooler: there is a pic below. The flap has a thing where something attaches to it... but it just hangs there in its "lower" position. The outlet on the other side of thefan housing has nothing in it at all. Can anyone describe to me (or post pictures of) how the thermostat and flap system works, and what parts are missing from my engine? I'd like to get it all back to how it should be. Thanks!
Menangler ·
Looks like most of the thermo parts have been removed, but they have left the single flap that directs air over the oil cooler probably the most important part.
You are missing the rod that attaches to this flap, the cross bar, the other flap for the other side, probably the small pulley that the cable runs through, the cable, the thermostate and bracket.
Not impossible to get if you realy want to make it right.
76camper ·
Not uncommon... most people used to think these cars were made in the stone age or something lol hence pretty much all engines not in once peice.
Its important to get this system back to stock... quicker warm ups means lower fuel consumption and engine wear... longer between rebuilds.
Looks like you need:
Main rod which both flaps connect to and the wire from the thermostat connects to
LHS flap
Main rod spring (very important... if for some reason the thermostat fails the spring will force the flaps into the hot position.
Thermostat
pulley
cable
The little rods etc that connect the main rod to the flaps
The plastic bushes that the rod sits in.
Its not very hard to put it back together just alot of fiddling etc... I might have a few bits and peices that u need i will have a look if your intrested. I think it would be a good idea to get this system working properly... in the long run you will end up saving.
good luck and i will post if i have any parts which may intrest you...
Purple Martin ·
Thanks guys, your answers make a lot of sense. I know I need to get this working because in Canberra winters my oil temp NEVER gets up to normal and I get "mayonnaise" under the oil cap... the low oil temps must be terrible for engine wear.
I didn't know about the main rod spring, that's a really useful bit of info, thanks. Did you mean to say I need the RHS flap, because the one in the pic (above the oil cooler) is the one on the left side of the motor (but the right side of my pic).
his@hervw ·
Does that flap sit on top of the oil cooler, if it does then the air acually comes out under the flap, as mine has a srew holding it down so it doesn't close accidently?????
this was after a rebuild at bribie Is The pulley that the cable runs around is held on by a small screw,, mine went right through into the sump, but sadly was left out when the flaps were taken off, oil pissed out every left hand corner. Have fun
76camper ·
Yep, was talking bout orientation of the picture... What happens is you install your thermostat in the bracket on the side of the sump under the pushrod tubes, run the cable over the pull up through a hole in the tinware and then on the main rod you clamp it down. You set it with the thermostat closed and push the main rod to the closed position against the spring and tighten it up. Then when the thermostat heats up it opens and releases the cable slowly. The spring pressure on the main rod pulls it open as the thermostat releases. Good idea to have this spring or there is no point in the whole system and if you leave it off it is likely the rod will fall to the cold position and you wont be able to cool your engine at all.
