Hey all,
Well I have finally found a good beetle for the lady of the house. She chickened out of driving the purchase home so it fell to me to get the new member of the car yard home. I sat on 50 mph all the way just to make sure I did nto cuase too much undue stress to a vehicle we have not had in our drive way yet.
On the drive home I noticed a number of things.
1. hand brake not functional (have since fix this. The design of the seems strange and if you do not have the cables adjusted correctly the ratchet will desintergrate right in your hand, usually resulting in the release button and rod hitting the dashboard, and mods to stop this happening???)
2. going around a roundabout and accerating out seems to give a very unnerving floating sensation? The car has been lowered slightly but not huge abouts. (pics to follow)
3. Gear selector seems to "stand up" once in fourth (ie drifts toward where 2nd would be) selection seems to be tightish but not as pecise as I would like (expect a aftermarket short shifter might be required here.)
4. The 1200 (i am lead to believe anyway) seems to have a slight "knock" to it and after some closer investigation it would seem the motor has been over filled with oil. Requires and oil change anyway so this will be performed sometime during the week.
5. Boot lock opens and slides at a 10degree angle thus binding on the runners etc and stuffing the pull hock thingy (real technical I know) how does one fix this? is it an adjustment.
6. There are many electrical issues. Horn, windscreen wipers, Head lights, stop lights (which I did not realise until after I got the car home.) The headlight worked out to be due to being mis wired. (ie highbeams and low beams, and ground where incorrectly installed on the globe, thus always running high beam when the light were turned on.) Since rewiring that section it was found that the dipper switch was faulty thus will be replacing with a new one. The stop light I am at a loss. The switch switches (ie end of master cyl) and 12V is at the switch but the light do not function out the back (only inds and tails work) the funniest thing is that when you apply the brake the voltage at the switch drops to 0V. What are the common issues with these. do they rub through anywhere?
Upon sorting and chasing both the headlight issues and the stop light I noticed that there is a wire haning above the master not connected to anything. Cannot remember the colour but it is hard the see what colour most wires are at present as most things are yellow :S seems when you spray a car masking is not too important... GRRRR(i am still casing the stop light issue...)
Is it common for the wiper motor to die in these or it more likely wired incorrectly? I suspect the previous owner was not electrically understanding, and thus just plug things what fitted.
Is there a switch (ignition) which incorporates a access position or is this something I will have to fabricate?
While I do like generators, particularly on a original classic, that fact that this car has already been converted to 12V (not sure of how well yet) The fact that the car will end up being a daily means an alternator may be the better choice. What is the easiest way to place a alt in the old girl. (could the windscreen wiper issues be related to the 12V conversion, having never done one in a volks.)
The inner rubber trim for teh drivers window seems not to sit nicly any pointers?
All in all for what we got I believe it is not a bad purchase. Infact for the 5 week understanding I have in the Beetles I think we have done brillantly. Anyways enough from me...
T
[ Edited on 21-2-2006 by firefly ]
firefly ·
