Giveing my old Vw trike a face lift 1993 ej22e
https://forums.aussieveedubbers.com/threads/49268/giveing-my-old-vw-trike-a-face-lift-1993-ej22e
Joewilldo ·
Frist let me start by saying hello too all you guy`s and thank`s for any input you all can give a newbie...
I have read alot about about Subaru engine swap`s on your web site I think it`s great well what I am trying to do is put an 1993 ej22e with 99k for mile`s into my old Trike with a 1966 Vw drivetrain as my old VW MOTOR has about had it...
Ok today I went and got the 1993 ej22e motor to find there was no ecu with it but the yard has a 1992 Legacy with the ecu and all the wire`s will it work on the 93 next thing I need too know is what I an going to need off the car to make it all work and where on the car it is like the ecu inside and with wire`s and what I will have to get from under the hood...
I order the the engine adapter kit today so I hope it will be on the way soon...
I also need to know I can lose off the engine as I will not need ACand what have u as it is a trike after I get the motor cleaned up I can jacked up into place to see where the water line`s need to go as well as where Im going to put the ecu again any help you all can give me in this matter would be great...
I want to thank you all for your time and your help have a great day... Joewilldo....
seagull ·
I have a trike with a ej20 legacy quad cam in it
you live ? by the way
The leagacy ej20 is not the ecu you need it will not work
to save me typing have a llok here by doing a search > top left of page with post by me Ie put in seagull , conversions .
you can remove the air con & if you ask at the wreckers they may have the pressed metal braket the the GX ( liberty came out with with out air con ) this will save you about 4 kgs of weight out the rear .
dont for get you need ( all the parts ) to make the motor run or you will be in more shit than the first setlers .
In short if the motor does not have all the wiring with it , go to another yard .you will end up looking for bits all over the place .flow meter , ignighter, ecu , key to start it ( some have transponder keys ( mine did )
seagull ·
ej22 with factory auto
seagull ·
what I see on the mistres
seagull ·
getting the gas out 2" 316 stainless steel , about 3 days work for me back then
I can see why my wife wants to leve me .I must stop building toys .
seagull ·
1641 street fighter vw manual goes hard
seagull ·
The newest toy , how will a ej20 turbo go in a trike mmmmmmmmmmmmmm
its going mid mount with a factory auto out the rear
see you in the wind , seagull
seagull ·
in the sun & out the front
