Engine troubles
https://forums.aussieveedubbers.com/threads/49275/engine-troubles
Chewy ·
Ive just put a 1800 type 4 motor in my kombi which was previously fuel injected. I bought it running in a kombi and it ran pretty damn good.
I stripped all the FI stuff off it since my kombi does not have the wiring for FI and put a set of duel solexs that were originally on an 1800.
Now that its in my kombi it runs like crap.
It sounds sort of OK free revving the engine up in nuetral but under load the engine pops and farts and carrys on.
With the timming set at 7.5dbtc advance the engine runs very rough, misfires a lot and will not accelerate under load.
With the timing set to a massive 40dbtc the engine runs a lot better but still pops and is down on power.
Any ideas?
Are both fuel solenoids opening on the carbies? If one has the wire off it or it is faulty, it can make it run like a bag o stuff. I dunno, just a thought. Auto chokes set?
Chewy ·
I didnt even know they were solenoids, thought they were part of the choke sytem so they are not hooked up, will go try now
Chewy ·
Didnt change a thing 🙁
It needs a lot of advance before it stops backfiring out the carbies??? :jesus
Anthiron ·
did u get carbies balanced?
are u sure of condition of carbies? could have idle jet blockage perhaps.
the fact that it has to be advanced so much could mean its running very lean.
vwking ·
hi what ya doing with the fuel ingection cheers:beer
Chewy ·
Hey mate, dont know yet, but if I end up selling it ill get in touch, have everything from fuel tank to injectors
Any one else have any ideas?
khanacross ·
hi, just a thought plug leads can break down under load and give smooth idle, also coil,,,,regards ken
76camper ·
definantly sounds like a carby prob!
here are a few sites which give a bit of a description on tuning.
http://www.aircooled.net/gnrlsite/resource/articles/dualcarb.htm
http://www.clubvw.org.au/tuning_tips_for_tips_twin_carb_k.htm
hope this helps a bit...
Seeing as they have that "central idling" set up - you 100% sure you got all the hoses in the right place??
With the motor off and looking down the carbs you are getting a squirt of fuel??
200% sure you got the firing order right??
jo_tas ·
And just because you hooked up the idle cutoff solenoids doesn't mean they're working! Check them!
