in the pics i attached i have a twin side plate g box with a clutch and 2 pressure plates what bits can i use in the pics ?
i think the throw out bearing isnt the right one does anyone know what is?
and the pressure plate without anything in the cente just pointy spikes is this ok? for this g box
11CAB ·
The throwout bearing in the centre of the picture is an "A" type bearing and goes with the pressure plate on the left. The pressure plate on the right uses a "B" type throwout bearing, and this is what is needed for the gearbox pictured.....
Does that make any sense?
the throw out bearing also slides over the center spiggot on the gearbox, so it must be greased and fit snug
t2 ·
that amkes sense, can you buy a b type throw out bearing new if so where from?, b type throw out bearing isnt the correct name is it?????????? also do they come with the required parts springs etc to fit it?
11CAB ·
You can get the throwout bearing from any VW parts place, and if you tell them its a "B" type bearing they should know which one. Its to do with the part number....they both have the same part number except for the last digit, one is an "A" and the other is a "B"
karmen ·
is your location Penny inTas
might make 'cents' to put state
and we can recommend a vw place
t2 ·
feel sorry for you if there is a penny in tas, im in penriff i have almost got a mullet too
where are you located ???
1500S ·
Did you see the garden sign on the west end which reads PENRITH. A couple of years back someone re-planted it to read PENRIFF !!
On that clutch, you can also opt for the other model fork and bearing and the only mod is to part off the extended seal cover/guide so that the "normal" A type? and sometimes more readily available pressure plate. Maybe a bush change for the fork shaft as well.
