Aussieveedubbers 路 Buying, Selling & Swapping Parts
FS: 1600sp Heads and big bore cylinders to match.
https://forums.aussieveedubbers.com/threads/49539/fs-1600sp-heads-and-big-bore-cylinders-to-match
Gibbo 路
Hey all, Just putting the feelers out trying to sell these on.
1600 sp heads, recent head work ($170) and used barrels from big bore kit to suit. Ive been told it will go from 1300 to 1600.
Four barrels in all (obviously 馃槈) no scoring, all in very nice condition. Also two pistons for the same set.
I will also throw in another set of barrels as well, they seem slightly larger and have more pistons with them.
$100 ono
Gib (Mark)
0401 719 913
QLD 4105
Moorooka.
[ Edited on 6-3-2006 by Gibbo ]
1500S 路
If it will take a 1300 to 1600, are they not just standard 1600 cylinders?
By the way, what's that blue junk around the cylinders?
[ Edited on 6/3/2006 by 1500S ]
Gibbo 路
Hey.
Im only going on the info that I was given. Can take measurements of the cylinders if needed.
Blue gunk is some kind of gasket sealant I think
Cheers!
tdegens 路
Any ideas about how to get them to coffs harbour?tom
1500S 路
Have a look on the top of the pistons for size. Nominal size is 85.5 mm (85.45 mm on pistons from memory) for std 1600 pots.
Gibbo 路
Will do.
Tom, Might see if anyone is heading down that way.
They are pretty heavy.
Might be able to get them down to the airport for you to collect. But cant promise anything.
Cheers!
Gibbo 路
Hey, I checked the pistons.
Nothing written on the outsides but inside the piston the ones with the big-bore kit is written 085107.
Inside the others is written W9201
Hope this helps.
Going on Ebay tomorrow.
Cheers!
Gibbo 路
Last bump before Ebay.
cheers all.
