Just cracked 200!
https://forums.aussieveedubbers.com/threads/49692/just-cracked-200
Dasdubber ·
Great stuff Jak - must be even more fun to drive now!
Alex Holzl ·
Wicked jak! Will you be out racing on the 9th at wakefeild?
And guess wat else is back in action!!! its green with a 2.7...
Alexxx
malcolm ·
jak how are the lateral forces on the rear tyres and have you noticed extra flex in the body due to the extra weight of the subie motor and also the flex on the gearbox.
seagull ·
Well I am starting with a $125.00 94 wrx motor
bat69 ·
200hps at the wheels..........Thanks Nice!
Hi Jak
Well done, I thought you were speeding when I saw your post heading, now I know you are.
Volkswagenboy ·
Ditto Steve.
boof2332 ·
Just checked the dates also....looks like I better join the porsche club so my 200++ ponies can have a go too! I had a practice at the creek a couple of weeks ago...I thought subaru would have made those 2.5 sti's quicker.
Is there anyone in Australia apart from Jak, who gets a gismo thats purpose is to turn up boost, and by simply utilizing the very function it was intended could give you 240+hp.......then refuses to turn it. Then again, if your primary concern is making sure your skirt isnt trapped in the door, and working out a good place to put your handbag, so as not to spill your makeup...200hp would still scare the shit out of me! Better hide that controller Rizzo, cause i'm turning it when I see it!
Matt.
p.s. Love the flat torque curve!
boof2332 ·
Better question.....where is JVL:thumb😘thumb🙄:thumb:o
boof2332 ·
Found him....intro section of REXNET
boof2332 ·
Who would have thought it was a place where you could pick up!:thumb:thumb:thumb:kiss
seagull ·
Jak , with my ej20 trike I have the rear now slaming to the ground under brakes .I have the torsion bars ( stock type three set as high as I can .The sump ( stock ) hits the deck and is a concern to me .My brakes are twin disks up front with a ford disk brake set up at the rear .
what is your car set up at the rear please
I dont know my power to weight but the trike comes in dry at 640kg + me at 95kg a bit of fuel
I thought all fords were Taxies ( ! )
speedster356 ·
Now, now....don't be bringing that sort of talk over to this forum.........
boof2332 ·
Make a new sump.....mine was a rush and leaks a tiny tiny bit...not enough to have made me weld ip a new one, and we now have a tig so its easier than before.
That may halp a bit.
matt
sounds good Jak hows the box n rest of the car holding up...
seagull ·
Jak , I need to add this is using my rear brakes on there own .I have a hand brake cly for the front .
Mat , yes I will make some mods to my sump .I dont know if Brendan is still about as I think he had a jig for welding the subaru units .
I will have to do it to the wrx motor for my new ride any way by the look of it .
cheers guys
jvl054 ·
Jak Rizzo wrote:just look for the bubbles.............:thumb:P😘o
Smartarse:kissJVL
jvl054 ·
boof2332 wrote:Found him....intro section of REXNET
:PJVL no comment!!!!
jvl054 ·
Jak Rizzo wrote:
vw54 wrote:sounds good Jak hows the box n rest of the car holding up...
Amazingly the car seems to love it, the extra weight has improved it's stabilty at around the 200kph range & the removal of the rear wing doesn't seem to have any effect at all, my $125 second hand gearbox is still holding in there as well, so are the original axles & CV! God knows how, it has definantly taught me to drive smoothly whilst chirping the tyres on gear changes.
regards
Jak
Chirping....there goes another box:thumbJVL
Top stuff - little cars beating big cars is so much fun!
