New \"Formula Vee\" Engine. 1st test run vid.
https://forums.aussieveedubbers.com/threads/49753/new-formula-vee-engine-1st-test-run-vid
tassupervee ·
Hey Guys
I thought I share some video footage of my new Vee engine being given its first run in a dummy car.
The video title/name was mixed up with another video so dont be sucked in by it.
I think the jetting needs a little attention, prolly a bit lean with the exhaust gas temps a bit high and it idles a bit fast for my liking but its all fairly promising at this early stage!
Enjoy: http://video.google.com/videoplay?docid=-236345357158387520
L8tr
E
speedster356 ·
WOW.....
koolkarmakombi ·
you need some pit babes dude, your team looks too professional!
bus914 ·
revs good, you must have a counterweighted crank. 😂
tassupervee ·
yer the crank is "special" bwaaahahahahahahahah!
Great vid tho!!!
L8tr
E
pringa8 ·
Wouldn't be surprised if some of the Vees in the series are running the same internals!!!😂
tassupervee ·
Herheheheheheheh we seem to be on the same page nathan!
L8tr
E
Scarlet ·
be nice and warm during winter, once ya get your heat exchange hooked up....
smeg me sideways!.... he he
pringa8 ·
Dont worry though Evan, fuel injection will solve all of those problems!!!!🙅
tassupervee ·
Bwaaaaaaaaaaaaaaaaaaaaaaaaaaaahahahahahahahahahahahahahahahah! Now why didnt I think of that?????????
Apparently, "they" are attempting to "re-invent" EFI for the Vees...............oh dear!
You get that on the big jobs tho!
ROFLMAO!
L8tr
E
pringa8 ·
I know, it's a joke hey. How bout a decent control cam, control heads and carby that works well? No no, it's the jetting that's separating us! :puke
tassupervee ·
M8, I cant stop laughing about that one.......................
There must be at least a couple of inch/Lbs available from a couple fo different jet changes. Wow, that must surely win a race!!!
And they would have you believe that is close to rocket science!!!!!!!!
Yer, the heads thing is a worry for the 1.6 brigade. They messed up their research there!
Same as the cranks, A lot of dramas would prolly go away with a counterweighted crank. But you cant have a bulletproof engine can you!!!
L8tr
E
koolkarmakombi ·
I am getting the drift tassie, want to elaborate a bit for us swine who dont know the v-rumbles as fvee ripples...
tassupervee ·
TripleK
Errrrrm, how long have you got?
To bring you right up to speed on things would take quiter a few afternoons and plenty of slabs!
Id be typing here for hours to outline some of the shenaigans going on.
There is a concerted "effort" to overly complicate the issue of jets in carbs. This is related to the "push" for EFI on F-Vee's.
There are perhaps a couple of dodgey cams (possibly Engle 110) running around from the Formula First (NOT FV 1600cc). F-1st is slightly different to 1600cc and is only really running in S.A.
There are various head castings, same as 1200, but unlike 1200, there is a vast difference in performance between the "good" ones and the rest.
There's an issue with cranks, cases and high rpm's that makes it a little hard for someone on a budget to build his own reliable 1600.
The list of other issues is endless as im sure Nathan agrees.
Actually I bet hes grinning from ear to ear here! (add guffaws of laughter)
L8tr
E
pringa8 ·
Yeah, unfortanately there's a lot of 'bending of the rules' and in some cases, dead set cheating. I think a lot of sealers are not doing there jobs properly and sealing engines with illegal parts. We had one bloke last year who was found out to be running illegal empi high flow heads while the rest of us (i assume) are using the standard 1600 heads as cast! The thing is he still didn't win the championship!
Basically, it seems honesty and ethics may be going out the window as winning at all costs (or budgets!!) is the main driver.
pringa8 ·
Unfortanately - nice spelling!!:duh
koolkarmakombi ·
aaaarh, kind of like 'bucket racing' in motorcycles, started all good then cnc rods, custom heads etc.
isnt there a restrictor plate?
TSV I wish I could have caught up for those beers when I was in tassie except I wouldnt put you through my destructochild (19 months) who was with us...
So efi will make it 'fairer' not
koolkarmakombi ·
I shall we say 'knew a bloke' who used the N02 cream chargers to let loose a dose through the inlet tracts on full throttle on a tuned fz750, would really help the get up and go until a fiston leaned out and melted, alloy piston top everywhere
pringa8 ·
Yep, same situation it appears.
We run restrictor plates on the 1600s, in an attempt to achieve parity with the 1200s. Personally I think they should ditch the plates and let the two run as a separate series, as they already really do anyway.
tassupervee ·
Nate
One thing is for certain, blatantly illegal engines are running. There is no question.
But, one factor that encourages this is the fact that the current fold up seals we use now can be unfolded just sufficiently to remove the tie wire without breaking, do whatever you like to the engine, and fold them up again. With considerable care, this can be done several times.
I have proved this! But apparently thjis dun matter.
I can hear you LOUD & CLEAR on the sealing/sealer issue..................................
This I heartily agree with but sadly its a fact of life in heavily controlled classes.
I have advocated a "claiming rule" on engines for years. Make the claim effective immediately for cash on the spot.
Make it, say oh I dunno, about 4 large. Thatll quieten 'em down a bit and discourage GP engines!! LOL
L8tr
E.
wombatone ·
There is noting new with people breaking the rules it had been going on for decades. There had always been those people that value a hollow victory win with cheating. This will never change and these people never stick around for long. After all where is the sense of accomplishment if you are knowingly cheating! As soon as you allowed modification away from standard, it is hard to control how far people will go. We built a vee back in the 80’s that was built doing every thing that CAMS did not have a rule for. Consequently they got one look at it and rewrote the rule. Funnily enough 20 years later it would fit right in the a modern grid line up, how thing change over the years but many they stay the same.
tassupervee ·
Thats exactly the case. There is no argument on how long cheating has, and will continue to go on in just about ANY category of just about ANY sport!
Funny thing is that the hollow victory doesnt come into it for some people.
There is a peculiar genre of competitor that does not see a problem with the saying "Its only cheating if you get caught" and so operates with that particular doctrine in mind.
I agree with Nathan, let the 1600's run unrestricted and as their own category.
1200cc engines have had their day. It is useless to try and invoke some kind of "parity", because there simply isnt any!
They are seconds faster than any 1200 could hope to be and are an entirely different animal altogether.
Im sure Nathan could confirm this. Just the addition of 25Hp completely changes the personality of the cars and the driving style changes so much it might as well be a different and new car......which it pretty much is!
KKK, Tassie trip....ahh well M8, there is always next time!!
EFI would even things up a bit (fairer)?? Mmmmmmmm......errrrrr.. wellll ahh yes it would actually but at a considerable cost to each competitor.
I would envision a cost of about 2 large per car and that would be plenty cheap!
Bottom line tho is that the issue of jetting a Vee is simply NOT as big an issue as plenty of Vee guys have been led to believe. Sure, it may help to a certain extent, but it is simply not to the magnitude that some guys who DEFINITELY DO know better would have many a poor Vee guy believe and unload his hard earned readies on unnnecessary jetting changes and "magic" carb mods!
Ahhh the fun and games of it all!!!!!!!
L8tr guys
E
wombatone ·
Your right the 1200 and 1600 are not in the same class. We are having the same problem in historic FF at the moment with people wanting to bring late (90’s) model cars in to the historic class. There are already two classes and the older car are already totally out classed. There is no was my old elfin could keep with 1600’s although the car did hole the Collingrove SA hill climb record for close to a decade.
tassupervee ·
Bring 90's model cars into hysterics????
How do they figure that??????
What, do they retrofit old coilovers and remove the long bellhousings and so-on....bugger me.
Historics are historics for a very goor reason........because they are!
tell me more!
l8tr
E
wombatone ·
I have not had a change to read all the info yet, but it is amazing how much a 90’s model car increases in values if they become historic. We were offered a Lola F5000 for $5000 years ago, had no were to put it and at that point in time there was no class to run in. The same car sold a few years ago for over $100,000. I’m not saying that the reason behind it, just interesting. Historic racing is an expensive hobby as you would well know. They are so picky with car not running the correct parts. We have had to cast up four new rear upright as the one on our cars were cracking. That that this was a problem, we found the original mounds. Just saying you crash then and it take a lot of time and money to put them back together if you can. This also could lead to new car coming in to the class as people are reluctant to racer the older cars. We have a mark 4 hewland in one of our car, when in England we when to see hewland to see if we could get spares. They did not even have records of the mark 4. So not really kind thing you want to spear into the wall backwards with.
tassupervee ·
I still find it incredible that a 90's era car could ever possibly be classes as historic tho...............
Your right ho. Hystiric racing and cars are big business.
A good M8 of mine down here runs a real Mustang. And by god the money those guys pour into those things is amazing!
L8tr
E
Volkswagenboy ·
That thing looks and sounds like a freakin' machine gun goin' off!!!!
-Staggers.
tassupervee ·
Hehehehee yer its a pretty serious bit of kit eh?
L8tr
E
Volkswagenboy ·
Sure is!
-Staggers.
firefly ·
In fairness and something that got introduced into a number of class where each compeditor builds a motor which then goes into a big motor pool. each motor then gets given to the compeditor based on a lucky dip. so you might end up with your motor or someone elses this will create parity and loose the cheating aspect quickly. 😉
T
tassupervee ·
Im right with you on this one.
however, the system falls down as there is a huge variation in time and money between different engines.
Given some guys build engines from older stuff and others do everything brand spankers.
if you could supply a pool of parts for the engines that are common to all then you can make this work.
The claiming rule solves most of the issues with guys unloading huge money into handgrenades!
L8tr
E
wombatone ·
It not just the part it’s the time and effort in matching them up and knowing how to screw the most out of what you’ve got. I know before the standard cams cam in it was common to match the cam gear to give you a little more back lash in order to change the timing. Pinson in up side down and all that, each little thing adds up too to vastly different engines.
tassupervee ·
hehehe absolutely.
With camshafts you can time the cam however you like now so long as its supplied by Wade with it's cam doctor report which is supplied to the engine sealer. Adjudtable gears, offset keys whatever.
The cam is specified by the FVAA not by CAMS.
Cams actually has nothing to do with the nuts and bolts of things other than rubber stamping any alterations,additions and so-on at Cams board level.
The entire thing is originally developed and administered by the FVAA
L8tr
E
