Subi EJ22 in rail build up
https://forums.aussieveedubbers.com/threads/49820/subi-ej22-in-rail-build-up
vwpete ·
Ok here is the start of my attempt at getting a EJ22 running installed and running on my rail 1st PIC is backend showing 1600 combie gear box and solid mounts
vwpete ·
here is the side view of me rail see that mass of wires? thats the subi liberty wiring harness. AAAARH help!, seagull i think u mentioned someone in wa who can sort this out. I don't want to have to send the wiring over east, and i really should not be allowed near wires.
vwpete ·
yeap thats a subi twin cam 92 liberty motor, Just need some, blue tack and sticky tape and i should be able to fit it to the gearbox. on the other hand seagull, i have u2ued to confirm need for adapter plate and flywheel🙂
[ Edited on 14/3/2006 by vwpete ]
vwpete ·
The subi is replacing this 2.275, motor, i wiped the cam again! and probably done some bearings, will find out when i pull it apart , I am hoping the subi will prove more reliable than this motor was. To be fair it was vgood on the road, i just think the offroading with so much constant oil sloshing movements and high reving it just kept getting oil starved, so once the subi motor is sorted, i will put it in the ghia.
vwpete ·
So anyways thats me so far, I will show progress as i go, i would really appriaciate any info for local contacts in PERTH WA for the following.
1) Altenatorto crank pully belt, I do not have the Power steering pump or air con so i need a small belt to run from the crank pully to the altenator, any clues where i can sorce one would be great.
2) wiring, info on how to do it, or on anyone who can do it
3) Adaptor plate and fly wheel for ej22 to 1600 combie
4) Shortend Sump for ej22,
MikeM ·
Not in Perth but.....
The boys at Custom Offroad in Brisbane have all this stuff on the shelf.
http://www.customoffroad.com.au/
vwpete wrote:So anyways thats me so far, I will show progress as i go, i would really appriaciate any info for local contacts in PERTH WA for the following.
seagull ·
belt part number = dayco SPK0640
wiring = I have a page here on the pin outs
Adapter plate = I have them comming now ( made my own & had them lazer cut )
Fly wheel = I had the subaru crank centers made & weld them into the vw fly wheel
Sump = I am making a jig to hold it , then getting the pressings done to tig it in
speed cut = I think you will need this but I will ask Christain if the box had that on it .
= You made a good move
seagull neil
good move
