74 Single cab....
https://forums.aussieveedubbers.com/threads/49857/74-single-cab
boof2332 ·
The 74 single cab that i got a few weeks back off the forum sadly has to go. The wife unfortunately has discovered that there may be more to the storey of its aquisition than meets the eye. Due also to the other projects I cannot keep it.
It is 74 2.0 litre. Just out of rego, little rough around the edges, although generally pretty straight. Motor runs well, just has a couple of oil leaks I need to fix(rocker covers etc.) Box is good.
I am in Melbourne for the Games till next Friday..I will post pics then.
Please call me on 0416 115 993 with any questions.
$1300 (what I paid)I had plans to respray it white over either a grey or blue with white bumpers....still can be done if required.(not for the $1300 though).
Matt
[ Edited on 15-3-06 by boof2332 ]
pete wood ·
any rust?
Pics?
boof2332 ·
The guy before fixed most...the only visable rust left is in the tray. Along the middle seam half way back...and just behind the cabin. It has been treated and is really easy to fix.
There is some rust in the gates that has also been treated. Apart from the gates being a bit beaten up...the sides of the ute itself are really straight. I was going to put wooden ones on it(cheap,easy and look good). Was also going to relocate the indicators.
Its really fun to drive.....pretty much the exact opposite of the beetle. I drove it from the moment I picked it up till it ran out of rego without a problem.. Did about 800 k's in 2 weeks.
I could probably organise a pink slip if need be...
I have no pics till I get back. Its at beecroft if you want to go look.
Matt
wacked1 ·
check u2u
boof2332 ·
Sent you one as I did not receive it!
Matt
dubbill ·
how much painted
boof2332 ·
Sort of depends on colour and how perfect you want it. There isnt heaps of prep in the car itself, its what you wanted to do with the gates and tray as there is a bit of work in getting that to look new.
Call me if you like Matt 0416 115993
wacked1 ·
did you get my u2u with offer??
wacked1 ·
i work weird hrs so can't get on to you.
dubbill ·
is this still 4 sale
