Quick tyre question...
https://forums.aussieveedubbers.com/threads/49858/quick-tyre-question
PrettyBlueBug ·
Is it ok to have 185/60R15's on the front... and 195/60R15's on the back of a Beetle?
:bounce
ian.mezz ·
should be all right if they do not hit body.
i have
205/65/15 and 195/55/15
PrettyBlueBug ·
Currently I have 185's on front, and 215's on back. Looking at something a tad narrower for the back...
Nice to see another Bug with teledials! :P
PBB
I have 195's 65 series on the back and 60 series on the front
I had 60 series on the back and it looked a little funny - a bit small
I will email you a programme where you but the size and offset and it tells you the diameter
I will post some pics with the different wheels
You may be able to keep the 215's if you have a bigger off set
OK - only have a pic of a 195 60 series
Yes - my rear is high, has settles since.
I just reckon a 195 60 15 looks a little small
just had a play with the programme
195 60 = 24.213"
195 65 = 24.98
185 60 = 23.74
PrettyBlueBug ·
Thanx Bizarre! At the moment PBB has a slight 'rake look' happening since I put the 185's on the front... so I'll be happy with 195's on the back if it will make her level up a bit! :P
Doug Sweetman ·
Yes its fine - I have 195 60's all round on my 1303.... I can identify with what Barry mentioned, but I did it as I wanted to reduce the rubber size in the rear a bit.....215's were a bit much the rims I have.
barls ·
i use to run 195 70s on the 14s i had and now have 205 65s on the 15s i now have. if your interested ive got some tire size calculators on my home computer and i can post later
oval TOFU ·
205/65/15 should keep the rolling diameter very close to stock.. ie: better fuel economy on the highways...
PrettyBlueBug ·
205's are too wide for the wheels I want to have, which are 5.5". I think 195's are the widest I can have on 5.5" rims.
Otherwise I'd keep my 215's as I love the look of them! Makes my PBB have a nice butt... 😂
oval TOFU ·
What rims are you thinking of getting PBB? I saw ya post to someone offering them for sale... what's up your black sleeve? 🙂
PrettyBlueBug ·
Oh Chris, how did you know I have black sleeves today? 😉
oval TOFU ·
...I know many things about you.......
btw, you have something stuck in your teeth from lunch. 😉 and you should use some product to fix your flyaway before you see your bf tonight at 7...
PrettyBlueBug ·
Nope, you got the last post completely wrong! :P
oval TOFU ·
dammit
PrettyBlueBug ·
DIY-DUB wrote:bizzare does this program you have calculate the sidewall height? because i want to know what tyres i need to keep it legal overall size and havent been able to work out how its done?????????? the profile thing, like whats the 35 40 75's in inches type thing...
Yep
u2u me an email address and i post on
barls ·
Pretty_Blue_Bug wrote:205's are too wide for the wheels I want to have, which are 5.5". I think 195's are the widest I can have on 5.5" rims.
no 205s are not too wide for 5.5 inch rims as this is what i have as well. try here pbb as this is what im using to figure out what im going to run
http://www.miata.net/garage/tirecalc.html
modulus ·
There is an online tyre size calculator at:
http://www.aussiekombicampers.com/projects_bbw.shtml
hth
