FS: Type 3 brakes late model
https://forums.aussieveedubbers.com/threads/49934/fs-type-3-brakes-late-model
GTMac ·
Have off my 71 Fastback, complete brake set up (front dics, rear drums and associated bits) and master cylinder. Calipers, brake lines and wheel nuts also included. Only thing needed would be the locking nuts for the front stub axles.
Good condition.
Pick up from Annandale. Asking $150
[ Edited on 19-3-2006 by GTMac ]
GTMac ·
Anybody, make a reasonable offer and they are yours.:repuke
GTMac ·
OK, $100 otherwise they sit in milk crate under the house for a rainy day.
bus914 ·
are the calipers the type with the bolt holes closer together? (the earlier style)
GTMac ·
Good question. Off a 71 model so cant remember but will check and advise.
GTMac ·
Bus914, you have U2U.
GTMac ·
Not sure what meat should be on a standard rotor but I have measured and both are at about 10mm thick. All I can say is they never shuddered and pulled up fine and thus assume are not warped etc.
if there off a 71 then they are the smaller front calipers they bigger calipers only came out on very late 72 and 73 models
