telling the difference between flywheels etc.
https://forums.aussieveedubbers.com/threads/49964/telling-the-difference-between-flywheels-etc
Anthiron ·
i have a 1776cc engine which will soon be ready to go into my baja.
my car has an old swinger box and i have no idea if i have a 6 volt flywheel on my current engine or if the bellhousing has been clearanced or even what flywheel is on the 1776.
is there a way i can tell? starter motor?
i dont want to drop the motor and find out i dont have the right starter motor for the flywheel.
Nick
pod ·
starter should have voltage stamped on somewhere ,plus there is a difference in the starter spigot sizes
tassupervee ·
Yep.
The starter shaft is a fair bit bigger on the 6V starter and the gear teeth are wider spaced as well.
It should be fairly obvious if you pull the starter out.
L8tr
E
