always replace condensor and points at the same time
is say this is your problem
pod 路
Yep as Anthiron says,plus if the condenser was fried she wont go馃檯
h 路
yep as they said above..
dubbill 路
do you know how to check to see if its getting a spark????
that is in the dizzy cap with the points closed ignition on and a non conductive (wooden,rubber etc) instrument to push open the points n see or even hear the spark
engines run on some basic ingredients ie fuel SPARK timing and compression and its in that order you should check at any break down
by the sound of it only one of these has changed spark see if the condenser rectifies the problem
