Caster angle on raised front end?
https://forums.aussieveedubbers.com/threads/50071/caster-angle-on-raised-front-end
Anthiron ·
ok so when u lower the front of the bug or bus you should get some caster shims to bring caster back to stock or closer to stock to improve ride.
so when u raise a front end does the oppisite happen? should caster shims be put on the top mounts of a raised front end? or does the raising just improve the caster further?
Nick
Anthiron ·
bump
karmen ·
would it make any diif as when u load a car the wheels r lower.
go ask the man at K-mart tyres Caloundra or Bob Jane matey
and see if he has tyres u wanted.
sorry will be in touch wnen i am down again.
raising it will give you better caster..............although this will reduce your turning ability.
Anthiron ·
ok so i lose turning.....what benefits does one get with "better" caster?
ancientbugger ·
Don't forget Nick you've raised the rear so wouldn't that cancel out the front?
Anthiron wrote:ok so i lose turning.....what benefits does one get with "better" caster?
better steering feel, self-centring tendency and straight-line stability. All good
Anthiron ·
oh im not talking about my car in particular barry im just interested.
though when i raise the front it would come into play.
mackaymanx ·
Raising the rear will not counteract completely the effect of raising the front, net result will always be more caster. Caster affects handling not ride.
