Aussieveedubbers 路 Tech Talk
\'73 dashboard fitting a \'75 model
https://forums.aussieveedubbers.com/threads/50172/73-dashboard-fitting-a-75-model
ByronBug 路
:sandrine
Would someone know if a '73 beetle dashboard fit straight in to a '75 model ?
Want to replace put don't know weather it would fit correctly.
Anyone done this?
Judy 馃檪
Bizarre 路
if we are talking 73L to 75L then no problems
just time and effort
Joel 路
hey judy
yeah there the same
pita job though
there was a flippy blue 73 Lbug just down the road from u in a shed for ages that had an electrical fire under the dash i was gonna buy it but couldnt find another dash for it
Joel
DoNkEy 路
from memory 73 has some slight differences from the 74, 75. Mostly vent stuff. It will work but there may be a few things that need adapting.
VWCOOL 路
Gloveboxes lids and latches are different and not interchangeable
Bizarre 路
i have had 2 x 74 and a 75
my mate has a 73
yes the glove box is different but that is all
If you have a "complete" dash is will not be a problem
Joel 路
the 74 on squeeze type latches must be soemthing of a rareity these days
i broke mine a few years ago and couldnt get one anywhere
the only one i could get new was over $80
i got one out of a golf at the wreckers its the same overall just shorter had to grind down the striker plate to make it latch
Joel
VWCOOL 路
Bizarre wrote:i yes the glove box is different but that is all
yeah good point
ByronBug 路
:sandrine
Thanks Guys for your imput... :thumb
Yes we have the complete dash to put in..
(Jess's dash is no good in her 75 bug & we wanted to see
if we could put a wreaked 73's dash in it instead)
....just needed to know weather it would fit ok
thanks again
Judy
ang3lsholocaust 路
馃樀 THANK U JUDY SO MUCH
your a life saviour
tahnk u for going to so much trouble :kiss
1303Steve 路
The panel in front of the dash where the defroster outlet is a bit different between the early and late. The early one has grilles cut in the metal panel, the later ones have plastic outlets.
ByronBug 路
Thanks Steve :thumb
