Aussieveedubbers 路 Buying, Selling & Swapping Parts
( MELB ) WTB: Manual conversion kit for 71 bug
https://forums.aussieveedubbers.com/threads/50349/melb-wtb-manual-conversion-kit-for-71-bug
Felony 路
Has the semi auto now, had problems with it going into gear, cant find a leak etc, so bugger it, lol, i want manual anyways, i need everything for the conversion...
PrettyBlueBug 路
Awww.... poor 'lil semi-auto! 馃檨
ctefeh 路
Felony,
Check my response in Tech Talk.....but....
if you're going to enter the House of Pain, here's a starting list of what you'll need to spend on :
From the engine lid going forwards :
Flat cam oil pump.
12V Flywheel, Cluth disc, pressure plate, TO bearing, Gland nut'n' washer.
Complete IRS manual trans (no axle's is OK).
Manual trans mount (for up at the torsion bar end).
Bowden tube for clutch cable (I think it's called that).
Clutch tube (examine your pan, you may have one).
Manual shift rod for your year of bug.
Manual shifter and stop plate.
Manual Pedal assembly.
The subject has been done to death on The Samba, lot's of info there.
Enjoy
Ctefeh
