(no subject)
https://forums.aussieveedubbers.com/threads/5057/no-subject
tap it to the next size screw?
no idea what size it is though :jesus
You would want to make sure no filing go into the dizzy though.
Use lots of grease.
Phil74Camper ·
You may be able to run a metric tap into the hole and remake the thread - it might not be too chewed to need to go up to the next size (is it?)
I imagine it's probably an M3 or M4 or thereabouts. Buying a metric tap and die set is a great investment - it's amazing how many times you will use it. Just cleaning up the threads on your good nuts and bolts is easy and well worth-while.
Here's a typical set - 16 pieces for $140. Your local engineering tool shop will have something similar:
http://www.justtools.com.au/prod2079.htm
70AutoStik ·
Yeah, weld a nut on with your arc and run the appropriate bolt into it.
OvalGlen ·
I'm hoping you meant wrecked the screw head,
which is just "use vise grips to remove and replace", but that would be too easy.
On the positive side : the dizzy could probably do with a full overhaul,
Pull it all apart and regrease, fix the screw on the bench
