Recieved my rebuilt frankfurt in the mail. negative seems to be bodied like everything else on the vw, positive running to ignition, and there the only wires.
the 6/12v converter on the rear is correctly set to 12, and on the otherwide from he power wire is 3 speaker holes with an image showing 1 speaker o 2 holes and then 2 speakers to 1 diff hole and one the same.
can someone explain this to me.
ill try to get an image.
[ Edited on 5-4-2006 by 53racer ]
kombikim ·
I have a similar radio, they are saying you can connect either one, or two speakers, -negative wire from each speaker goes to one plug, & postive wire from each speaker must go to its own plug,
one thing that is stressed with the Blaupunkt radio is that you must NOT turn on radio under any circumstances without a speaker fitted
53racer ·
what connections do i use? a bullet 'spade' plug or a banana plug?
kombikim ·
original special plugs---- dunno where you would get,
the Porsche guys jam the wire in with a matchstick-don't tell anybody!
53racer ·
are you serious :S
may crack open the rear and see if i can hardwire
kombikim ·
yep, serious, poke the wire in & then a match or something to hold it in, thats how a few people have done it, I have no idea where you would get the original plugs to so;der on to the end of the wires - sorry
53racer ·
no worries, TY for the info.
just noticed you live like 5 mins away from me, hehe
53racer ·
just thought i'd add here, in just then cracking open the case i noted that the connections are merely a plug type connection and nothing greatly special about them, bullet type 'spade' connectors or small series banana plugs can all fit snugly into these and provide a decent connection.
53racer ·
kombikim wrote:I have a similar radio, they are saying you can connect either one, or two speakers, -negative wire from each speaker goes to one plug, & postive wire from each speaker must go to its own plug,
hey i know it seems a dumb question, but would the output be left and right, or just mono x2
kombikim ·
mono
I should add that the stereo radio did not come out until 1969
Blaupunkt was the first with this feature
[ Edited on 7-4-2006 by kombikim ]
kombikim ·
only 5 mins from me? oh well, if ever you need help..............
53racer ·
😀 ty. may see each other in passing 😀
Robo ·
Just a thought. I wonder if you could get a fitting from Tandy or Dick smith?
On a similar subject, what sort of speaker can you use with these radios? and can you buy one new.
Rob....
Robo ·
Could also try these mobs.
Nostalgic Wireless Company
Pre 1970 car radios restored, vibrator type converted to transistor, 6 to 12 volt conversions,
Valve Radio repairs, restored radios for sale, AM to AM/FM conversions.
Contact:
629 Canterbury Road, Surrey Hills Vic 3127
Phone (03) 9899 8880
Fax (03) 9899 8887
TY for the info dude.
i bought mine in restored condition, so is cool. simply needed connections. i'm putting jaycar speakers in, mainly coz i work there i get them cheap. simply any 4 ohms will do.
