Carby Question
https://forums.aussieveedubbers.com/threads/50680/carby-question
Midlife crisis ·
I have put at Solex 34-3 carby on my 1600 BAJA about 2 months as the carby I had on it was 31 which was set up for a 1300.
I put a kit through it before I put it on.
I was playing around with the mixture screw, With the engine running I can screw it all the way in and it makes no change to the revs, I thought it would increase a little as it leans out?
The cars seems to a bit heavy on fuel as well.
Any ideas would be great.
Marc
ctefeh ·
Hi,
Did you clean and throughly air blast all the passages/jets when you put the kit through it?
What about replacing the O-rings on the screws?
Throttle arm set correctly?. Lot's of little feed/vac holes near the where the plate stops.
Slop in the throttle shaft? That'll kill one of these carbs.
Rob and Daves site www.vw-resource.com has a great article on proper set-up of the 34 Pict 3. You have to set lean best idle using both screws.
Regards
Ctefeh
Anthiron ·
if the other screw is not set properly u can sometimes screw it all the way in and make no difference. have a look on the rob and dave site and re tune it.
