WTB Straight Axle Conversion
https://forums.aussieveedubbers.com/threads/50736/wtb-straight-axle-conversion
vsleepy ·
As the title says, want straight axle conversion, brakes and tranny not needed, just the rest!
(but will take drum to drum if thats what you want to get rid of)
email me:
james at eappointments dot com dot au
phone me:
0400 143 172
cheers,
James
Kombi_Rescue ·
try darren T2 on DSK he just took his out and wants to sell it cheers steve
vsleepy ·
Thanks for the tip! I guess he just fitted one of your irs' eh?
vsleepy ·
bump... Still Lookin
vsleepy ·
Made one before? then quotes to make me one will also be considered!
James
t2 ·
i could sell you mine but will have to check they are the correct length so you will not have any probs with them ,i will make any neccessary adjustments, what you will need to do is get a template of an oval springplate , well thats the spring plate i used and cut your splity spring plate to the same bolt holes but add slots so you can adjust for wheel alignment, you could get them cut through most engineering places laser or water cutters would be ideal.or you could use a grinder and oxy if you feel confident
$200 plus post for the tubes
then when you are sick of looking at the possitive camber on the straight axle conversion go out and get irs .
your spring plates will be fine as there is plenty of meat left on them to hack into it a 68 bus irs spring plate copy.......... save the cash and go irs but if you want then tubes let me know its up to you
thanks darren
[ Edited on 15-5-2006 by t2 ]
[ Edited on 18-5-2006 by t2 ]
vsleepy ·
Hi Darren,
Have you managed to get your irs fitted? How much can you drop it with the irs. Ive heard that only about 3" is possible?
James
