Aussieveedubbers 路 Tech Talk
auto-electrical question
https://forums.aussieveedubbers.com/threads/50931/auto-electrical-question
cray 路
12.5V from the battery terminals when the car is idle on a 1600cc beetle with a generator. nrma batteries guy reckons that means my generator is stuffed. local auto-electrician reckons it's fine.
aussieveedubbers reckons ________ ?
thanks 馃檪
68AutoBug 路
Sorry,
12.5v is too low to charge Your battery...
Should be closer to 14 volts....
12.5v may keep You going as the battery will often go below 12 volts after cold weather or starting the engine..
Best of Luck
You should be able to pick up a good used generator easily...
cray 路
really? even vintage veedub reckon 12.5V is normal.
vw54 路
Yep 12.5 at idle is great
when you rev it up the voltage should go to around 13.5 to 14 volts
pretty easy to test with a multi meter
Bizarre 路
I agree with Lee
Can you call Rivo electrical - 9627 1874
I would trust an auto elect
cray 路
i have to say i'd probably believe dave over my local auto electrician.
and i don't think i really trust paul at rivo auto-electrical though. i've had a couple of problems with him in the past.
[ Edited on 13-4-2006 by cray ]
Bizarre 路
OK.... i have learned something 馃檮
Always thought you got 13.5V
blutopless2 路
i agree.. check it at revs not at idle
bond 路
have had issues in the past aswell - if you get ~14v at revs than all is good
nick
cray 路
blutopless2 wrote:i agree.. check it at revs not at idle
tell that to the nrma batteries guy :P
