does anyone out have one or more of these dizzy's lyin about 馃檪
1303Steve 路
Do you want it for a WBX or an EFI project? There are other dizzies you can use for EFI.
76bug 路
hi steve,
yeah its for a EFI project, reason for chasing this one is it has no mechanical or vaccum advance. wot other dixxies did u have in mind?
76bug 路
bump
1303Steve 路
Sorry didnt see your reply.
I have used a 2.6 EFI Magna one. It has 2 sets of pickups, 1 is TDC the other is piston position. Its a pretty easy job to have them altered to fit into an aircooled case. The only drawback is that they are fairly large in diameter, about the same as a 40 hp dizzy. The WBX dizzy only has piston position so you still need a TDC reference, the WBX used a magnet mounted on the case with 2 prongs sticking out of the flywheel for TDC. The Magna dizzy is a much neater setup.
greedy51 路
try volkshaven in campbelltown they are wrecking a few
Volkswagenboy 路
I have two Magna distributors here for sale.
-Staggers.
