The beetle won't run, turns and fires, but very very stuttery/spluttery.
Won't hold revs and engine stops.
I suspect fuel blockage or similar.
Whats the best way to try and find it, the filters look fine.
Am using twin 36 idfs.
Any suggestions for the not so mechanically minded?
lugnuts ·
Hiya Kafer,
1.was it running good before
2.change anything recently
3.have u filled tank recently
4.maybe blocked idle jet
Kafer Lover ·
Hi,
Was running Ok until recently when it cut out while driving along.
That turned out to be the electronic ignition had died.
I have since put points back in and had it running. However after a lap around the block to check after points were installed it started coughing and spluttering.
Limped home, but now won't keep running.
Its not out of fuel.
Check you points again - the gap might have closed up etc - and timing
I agree with ^
Points are CRAP these days and even new points need to be carefully checked.
I have seen them with no spring tension at all
You could have blocked idle jets.
Luckily on IDF 36's the idles are on the top
Hopefully you put a cut out in your filter base otherwise you will need to take your linkage assembly off.
They are the brass screws next to your emulsion stacks
If you happened to have on or 2 blocked it wont idle.
