Hi. Was wondering what involved in putting a pre-67 body on post-67 pan. I've been told there are changes involving those mounts above the rear wheels, but nobody seems to know exactly what (i.e. whether they are higher/lower on the post-67 pan).
Thanks for your help.
Menangler ·
The mounts on the pre '67 body need to be shortened, can't remember how much, about 25mm?.
The rest bolts over
bugmeister ·
Do you mean the actual mount in the wheel well of the body? Isn't it spot welded? Do I simply relocate it higher/lower? Sorry for the fifty Q's.
No you just have to grind about 25 mm off the lower section . Dont try n remove it from the inner guard. just reweld a flat plat in the bottom of it again with similar hole to allow body to be bolted down.
