recently put my 1600 back into my baja. this involved rebolting the clutch on.
car has developed a little bit of a shudder when letting out clutch.
how tight should the clutch bolts be?
if theres a bit of oil on the clutch then can i clean it off with something?
Nick
h 路
hey when you installed the cable back onto the box the thick rubber tube the cable runs through near the box end, should have a decent bend in it, as if it is straight shudder will result.. had the prob before.. have a look, usually not to hard to rectify..
usually when oil gets on my clutches i chuck em and get a new one (now there not that dear compared to pulling motors in and out to try n fix em) cause when they heat up the oil will always come out of it.. god dammit.... again you could light it up and try n burn the oil off... 馃檨
good luck nick, paul
Anthiron 路
i didnt have to take the bowden tube or cable off but ill check that anyway. thanks
bond 路
did you use a clutch/flywheel aligning tool?
clutches should be handled like glass from the sides?
nick
76camper 路
mine shudders a bit aswell, its slowly getting better. I thought it might have had something to do with those springs on the clutch plate....
barls 路
could be misalignment of the plate, oil on the plate or just temperamental
Anthiron 路
i used the ol' "one eye closed have a good look at it.....yeah thats straight" technique.
