Accelerator pedal pin keeps coming out
https://forums.aussieveedubbers.com/threads/51411/accelerator-pedal-pin-keeps-coming-out
Purple Martin ·
The accelerator pedal pin keeps coming out of the hinge at the bottom of the pedal in my 1959 bug. What can I do to keep it in place?
[ Edited on 26-4-06 by Purple Martin ]
Yogie ·
You can buy a new kit for the later beetles but I am not sure about the early ones though. With mine, there is a wire that wraps around the pin and there is a little cutout that it sits in. This helps to keep it in but you can also crimp the brackets on the floorpan a bit to tighten around the pin once it is in position.
Good luck.
Yogie
do u have the return spring on the pin its pushes the pedal into position
Doug Sweetman ·
yes, return spring is a neccessity, stops the accel pedal flopping back onto your foot....
Put a bolt through it.
