Aussieveedubbers 路 Rods and Rats Forum
what are the chances of?....
https://forums.aussieveedubbers.com/threads/51474/what-are-the-chances-of
Boozer 路
of getting a volksrod registered here in QLD with a beam extension like this? I don't think they're very good but i'd thought i'd ask anyway. cheers
pete wood 路
nah man, don't do it, extend the pan properly if you must, it's can't be that hard and it's be much stiff than a dodgy extention like that. There is always a good reason why engineers won't allow mods like that and it's not because they are kill joys, it's because they don't want to see nice people like you get killed. 馃ゲ
Boozer 路
fair enuf. i see your point. how would you go about extending the pan then?
greedy51 路
take it to ya local engernear and ask
shaihulud 路
Be aware that under the new ADRs to extend a pan is the same as to shorten it. It is to modify the pan away from factory specifications. That means that for rego purposes you are building an Individually Constructed Vehicle (ICV) and all of the modern ADRs apply. Such as a modern non-aircooled engine etc., etc., etc.. As someone who is building an ICV I would not recommend it as something to inflict upon yourself without a lot af prior thought.
Doug Sweetman 路
Hijack warning !!!
What ICV are you building ?
kroozzn63 路
is that from volksrods?
helbus 路
shaihulud wrote:Be aware that under the new ADRs to extend a pan is the same as to shorten it. It is to modify the pan away from factory specifications. That means that for rego purposes you are building an Individually Constructed Vehicle (ICV) and all of the modern ADRs apply. Such as a modern non-aircooled engine etc., etc., etc.. As someone who is building an ICV I would not recommend it as something to inflict upon yourself without a lot af prior thought.
Are you sure? I have done a limo, and the engineer said you can extend a vehicle as much as other limiting factors allow you. Weight increase, braking, tyre load rating, ride height etc.
It is modifying the original chassis, by adding to it. But shorten it and because you are removing part of it, you have a different situation.
