Aussieveedubbers 路 Tech Talk
why my flicker dont flicker ?
https://forums.aussieveedubbers.com/threads/5149/why-my-flicker-dont-flicker
SKEWtYpe3 路
my indicator, some times i put it on and its fine. other times i put it on and it ticks a couple time or never. anyway when it stops ticking i can WHACK the steering wheel and it turns on perm. or for a second. if i play with the hazard lights it rarely turns back on. continual pressure on the steering wheel generaly keeps it on.
its a 72 squareback - with problems
thanks in advance !!!!!!!!!!!!!!!!!!
:bounce
SKEWtYpe3 路
i kinda figure its a loose wire but wont to hear if anyone has had this problem and if its maybe something else b4 i pull the thing apart
馃檪
vw54 路
It will be a wire in the quick disconnect plugs under the steering coloum they usually pull out of the plastic plug that they clip into.
squizy 路
Could be the ticker switch relay.
Squiz.....
sand kombi 路
May be the indicator switch itself that is faulty (how old is it )and is occassionally losing contact on the switch
sikdub 路
Id check the earth on your flasher relay.
Steven 馃檪
SKEWtYpe3 路
thanks guys, so probably the loose wire thing, cool doesnt sound like it would/should be bad
how old is it, made and installed in 72 dude !
cheers all
:bounce
