Wanted - IRS Control Arm (Drivers Side) - Brisbane.
https://forums.aussieveedubbers.com/threads/51490/wanted-irs-control-arm-drivers-side-brisbane
MikeM ·
Hi All,
Turns out my drivers side IRS Control Arm is bent. Only a little bit bent (I didn't look bent until I bolted it to the car) but it's bent enough to completely bugger the camber on the driver side rear wheel.
So I'm after an IRS control arm for the drivers side rear. Can be bare, no brakes, axle etc. Or complete.
I'm in Brisbane
U2U is best.
Are you sure its bent??? I can change the camber by up to 4 deg without any problems, but there is a trick to it !!
