Stock starter turn over ej20t?
https://forums.aussieveedubbers.com/threads/51675/stock-starter-turn-over-ej20t
Klaus ·
About to start ej20t conversion into 68 squareback and wondering if the stock starter can crank it over, if not what have you guys done . Auto starter, hi torque one?
gull ·
My ej20 quad cam n/a motor would not turn with a stock starter freeding 12 volt direct
I went with a kombi auto unit
kevo ·
i got a stock reconditioned 1800 starter for my V8 conversion and like the gull says... turns over with no stress at all
ratbug ·
my ej20 n/a turned over fine with a standard beetle starter and a tiny battery. I now have a kombi box and starter and it turns over the same.
an ej20t should be easier than an n/a motor because of the lower compression.
yeah no worries
seagull ·
My ej20 n/a has the same heads as my Rs liberty same part numbers
the ej20 n/a is a 2ltr 16 valve ( legacy )
the rs turbo is a 2ltr 16 valve ( legacy )
and they go like 40 basterds each !
screw air cooled
Klaus ·
cool thanks guys i've got various starters lying around ie 1800 , 2ltr , 6v plus recon 1600ones and also know of a auto t3 square back if I get desperate for sale cheap.
I'll soon find out as i'm picking up rs front cut tomorrow for 2500 with only 55000 on the clock.
72RSbug ·
I've heard about stock 6v starters being used in a 12v car on a suby engine but have no experience with it.
ricola ·
I used a stock starter no problem with my EJ20t..
Rich
pete wood ·
I too have a standard 1800 starter turning my NA 2.5l Ej. I reckon the trick is the earthing. I suggest running an extra battery strap from one of the starter mounting bolts back to the -ve pole on the battery. All my starter problems disappeared when I did this.
Baja Wes ·
I run a 2L box with stock 2L starter on my 2.5L high compression V6. So it would have no worries with the suby.
choppa ·
Yep.
Ive got a crapy old 12volt T1 starter that I pulled out of the pile, turning my EJ20T. Its been in there for about 8 years now I think. No probs.
Last year gave it a birthday and bought a brand new 40 buck battery from super crap!
Check the bush in the trans, that needs to be good or new. They are only a couple bucks anyway. Might as well replace it now.
Good luck!
