Does anyone have a good second hand indicator stalk assembly cheap in Brisbane? (Both of mine are shot!)
Brenton Barry
0404746568
Boronia Heights
Thanks,
-Staggers.
ragtopp ·
Ive got a good one the whole cluster with the ignition and key, wiper and hi beam switches out of a 72 super if you get stuck mate, $40 for the whole thing.
There are 3 different model switches for late beetles, make sure you get the correct one.
Volkswagenboy ·
Yeah, mine only has the indicator switch/dip switch on the column.
Although, I may want the dual stalk one for my '72 Super, as it only has a single stalk (Early '72).
-Staggers.
If you want the wiper & turn switch set you will aslo need the housing, not a big deal to swap over, make sure you get the loom from the switches to the fuse box.
Volkswagenboy ·
Yeah, I'll be rewiring the whole car ('72) anyway so that's no problem.
-Staggers.
the differences between the 68 on ones arent real big
i've got the one from my 71 superug in my 74 Lbug
and i know the one from my 68 beetle could also be made to fit
they all use the same 4 screw mount and are the same shape
the diff is mainly in the wiring, the 72 on ones used a plug setup
Joel
VDUBXTC ·
I can bring both a single and a double to valla if you want.
Hole set up $20 each
I can post 1 if you are desperate and you can pick the other one up at valla with the rust repair sections.
Postage is at your expense
MISS VDUB ·
bumpski
Volkswagenboy ·
Yeah Manx, I'll probably take those.
-Staggers.
donn ·
Still learnn, what, where, is this valla I keep hearn about?
Volkswagenboy ·
Volkswagen Spectacular in August.
-Staggers.
donn ·
OK thats what, but where? and what sorta things go on there, just show or is it a swap meet as well? Other things involved?
VDUBXTC ·
Don, Valla is huge mate.
3 to 4 days of Volkswagen heaven.
There is a show and shine, there is a street parade, there is racing, there is a huge swap meet, There is plenty of drinking and just general good times.
Its about 4.5 hrs from Newcastle.
