Has any one striped a ej20 quad cam n/a down to see if it has the same internals as the ej20T ?
same motor one has turbo one has not
possable to turbo the n/a by fitting a rs inlet ect on ?
:beer
pete wood ·
The compression would have to be different. The RS motor 8.5:1 from memory VS the NA motor 10:1. I think the turbo motor also has oil sprayers pointing on to the back of the pistons but you'd have to confirm that.
GTMac ·
Different cams, different injectors and as Pete said, compression ratio different.
Doug Sweetman ·
yep, oil squirters on the turbo models arent present on the NA
