standard rockers??
https://forums.aussieveedubbers.com/threads/51873/standard-rockers
76camper ·
Hey guyz, im going to swap rocker assemblys with a spare set coz i think thats what might be making the ticking noise... They look identical to the ones on my head except maybe the adjuster screws are smaller.... are these rockers stock?
[ Edited on 7-5-2006 by 76camper ]
dubbill ·
better to turn up your stereo:P but really i cant see what swapping rocker assemblies will do much more likely to be a lifter or a sunken vlave/loose guide jmpo
dangerous ·
Photo?
What kind of engine?
66deluxe ·
Your spare set may be the sought after 1700 type with 8mm adjusting screws same as type 1, therefore you can get a set of swivel feet adjusters and they will make it run a little bit quiter. Scat or 911 adjusters are the ones to use.
76camper ·
bugger didnt realise the pic didnt come up. Ill measure the diameter of the adjuster screw later when i get home from scool...
