it supposedly works, looks very nice and even has a little red lens for a chiptourqe or similar shift light. it is an impulse type (coil wire must loop through a little tab on the back). panel mount, from an MGB.
[ Edited on 8-5-2006 by bus914 ]
MickH 路
if your giving it away i'll take it!!馃
bus914 路
yep, giving it away, come and take it.
karmen 路
ha ha he is in townsville
fares are cheap but i'll dibs it 2nd and send u the beers or the $$$ to pay for post bus914
would go well in a 36hp orig oval
need any kombi stuff 75 panel i;m parting
MickH 路
bus914 wrote:yep, giving it away, come and take it.
You have U2U!!!:bounce
VWFOOL 路
dibs if its still available
modulus 路
The Smiths gauges are nice looking units. If it's from an MGB (it looks like it), be aware that these are *positive-to-earth*, in contrast with the vast majority of cars including all VWs, afaik, and won't work on a negative-to-earth car.
hth
bus914 路
no it isn't
modulus look at the pictures it even says negative earth.
modulus 路
You're quite right! Looks like only early MGBs were +ve to earth, as I can see both +ve and -ve ons advertised on ebay. Mine was a '64, which was +ve earth. This must be from a later one.
