Name that sensor
https://forums.aussieveedubbers.com/threads/51945/name-that-sensor
72RSbug ·
While finishing up cleaning the loom on my EJ20TT I discovered 2 sensors were not hooked up to the ECU.
The bottom was (which I think is the crank sensor) is hooked up and the top right one also (water temp sensor?)
I have no idea what sensors the top and bottom ones are on the left, anyone?
subaruboxer ·
Hi Tom,
I think the big one is the oilpressure sender and the small one in the background is the gauge sender for the water temp!
Jörg
72RSbug ·
I was thinking the water temp sensor was not hooked up as it took at least 10 times to get is started when cold and I had read that the cold start sytem relied on the water temp sensor.
ricola ·
I agree with Jorg for both. The water temp sensor that IS hooked up is the one the ECU uses so that shouldn't be your cold start problem, the unconnected one is only used for teh dash gauge.
Rich
boof2332 ·
The one at the front is oil pressure switch. The one with the plug on the right is the waterl temp for the computer and the tab next to it is the water temp sender for the dash gauge. Your car will not know how hot or cold it is if the plug(water temp sensor) is not hooked up. You will not have your oil pressure light on your dash hooked up either. I have also heard that the alt light needs to be connected to complete the charging circuit...I think it happened to Jak when first wiring up.
Matt
72RSbug ·
I had the 2 connectors on the right hooked up while driving it, strange that it started so difficult when cold, any ideas on that? Boof, you are correct about the dash light, I had the same problem at first. Funny is that with the stock engine my volt meter indicated 13V at te max with the lights of and with the suby in it that was 14.7V 🙂
boof2332 ·
Is your idle up motor still operational?? I think it is hard to get a motor with a stock ecu to run engines with evrything different from air intake, exhaust, flywheel weight, then take away pwr steer and aircond pumps, make the car lighter and change gearing and loads. I believe its beyond the tunable parameters of the ecu. They still will work, although to what potential/contsant porblems.
Matt
72RSbug ·
interesting, and where exactly on the engine is it located (any way of testing if it still works?)
hotdog008 ·
BOOF2332
i have no prob`s with stock ECU and i have everything you mentioned
it starts ,idles, runs,goes fantasticly
so i am a big fan of stock ecu
hotdog EJ20T MANX
badvw68 ·
Hotdog008 - Where are you located? Do you have any pictures of your car?:thumb
