*wanted* 8mm case studs
https://forums.aussieveedubbers.com/threads/51993/wanted-8mm-case-studs
Stanley ·
Does anybody have a complete set of genuine 8mm case studs.
By genuine I mean not locally manufactured. Only the good stuff. I have some 10mm if your interested in a swap.
Send u2u or email stanley111@optusnet.com.au.
Midlife crisis ·
Are 8mm the standard ones?
Are you looking for new or second hand.
Marc
[ Edited on 10-5-06 by Midlife crisis ]
Stanley ·
2nd hand would be fine.
I'm pretty sure they are standard on some engines. 10mm was the other option.
Midlife crisis ·
Well I have about 3 dead cases here if you want to come around you can have as many Case studs as you need for free.
Marc
0410920488
RISKY^VW ·
mmm i think 8mm stuff are most after market for big bore to save the case from been to thin and cracking... not sure
Stanley ·
8mm studs were off later model engines I believe. 70ish on. Feel free to correct me if i'm wrong.
Calcool ·
Hi,
By case studs I assume you mean the 16 Head Studs.
I am sure I have a complete set S/H with nuts and washers.
If you are intertested at $50 for the set let me know.
David
0418 117 622
