Gen/Alt Strap
https://forums.aussieveedubbers.com/threads/52060/genalt-strap
mackaymanx ·
Here is a mod I made today to mount my alt, I used a 113-121 mm S/S hose clamp. Just a tip, I always find the mounting strap are pretty knocked around from overtightening and in this case was sitiuated under the oil breather.
tassupervee ·
That is an excellent suggestion!
L8tr
E
mackaymanx ·
Thanks, this clamp is a Tridon. Mikador? make one identical to this. Not sure if the gen would use the same size but its ease to check
The factory clamp is the same for both 12 volt generator and alternator models. There is a bit of shape in the factory clamp, did you reproduce it?
MickH ·
The "shape" will reproduce itself when you do these clamps up.These are a LOT stronger than the factory clamp and are easier to tighten and look better...
mackaymanx ·
Yes like Mick said they tend to shape them selves when you tighten them up but I gave it a helping hand with a soft hammer.
