stud pattern, for t4 96 mode?
https://forums.aussieveedubbers.com/threads/52129/stud-pattern-for-t4-96-mode
kroozzn63 ·
looking for wheel options for my t4 dual cab ?
i saw some merc kompressor rims +tyres cheap but im unsure what suits does anyone now wat nice rims and how tall i can go?
pod ·
just make sure they can be used on commercial vehicle ie insurance hassles
Desert Bug ·
Stud pattern is 112 PCD same as Mercs and Kombis from '71 thru to current. Check the width and the ET of the standard rims on your T4 and use this info when looking for rims. Have a look at what is available for Merc Vitto van as the load rating would be appropriate and the offset (ET) would be close.
Cheers.
VolksFolks ·
http://www.masterwheels.com/FitGuide.htm
5 x 112 pcd
Andy
[ Edited on 13-5-06 by VolksFolks ]
h ·
hey.. sorry to highjack.. but this would be the same for my 98 T4 as well then.. cheers paul
As Pod said be carfeul. You need to read the tyre placard on your car and make sure any tyre you fit meets the load and speed rating on the placard, otherwise some nasty insurance guy might say your car is not insured, just when you need it to be.
VolksFolks ·
a t4 panel van weighs less than a merc saloon, most rims are around the 680kg mark so should be save as, unless you are carrying real heavr stuff of corse!
kroozzn63 ·
Thanks Guys
The weight of the donor car is irrelevant. The important thing is what your vehicles tyre placard says.
