what product to use to clean carbys?
https://forums.aussieveedubbers.com/threads/52202/what-product-to-use-to-clean-carbys
lohoon ·
Hi,
I have some webers that have been left sit with fuel and water in them and have brown and white crusty stuff in them.I've tryed carbi cleaner.Anyone had any success in cleaning this out?
tassupervee ·
Carby cleaner, a toothbrush and good old elbow grease m8.
keep at it.
l8tr
E
kombidaze ·
just done the same with a set of 36 alfa webers bought from evil bay looked good from the outside but when pulled apart very ordinary inside. 🙁
carby cleaner and wd40 pressure packs and small plastic tube, all clean now. I will carby clean all orifices again and then compressed air blow out, new rebuild kit and check float level and should be ready to bolt on.😵‍💫
type3lover ·
Nothing dissolves crap like carby cleaner...maybe I should have worn gloves all those times! :o
Toby
urban_myth ·
yeah make sure you wear gloves with the carby cleaner, my hands stung for days after I used it... nasty stuff
oval TOFU ·
try different brands of carby cleaner - some stuff can be real volitile - and that's good!
koolkarmakombi ·
any tips on a **good** (read bad!) brand?
ultrasonics are good cleaners
Special Air Service ·
I was under the impression that acetone was the weapon of chioce for this sort of thing.
Brendan
toplessbug ·
nulon in a big tin bout 10 bucks --excellent
fekkinell ·
yeah nulon... it smells nice too 😀
dutchy ·
pull them apart and get them acid dipped (from your local carby place)
kevo ·
cloth, old tooth brush and for the tight bits use cotton wool stick things (making sure you pull the cotton wool out with the stick when done)
cleaned my twin SU's like that, they were filthy wen i got em
