type 3 irs manual same as auto?
https://forums.aussieveedubbers.com/threads/52244/type-3-irs-manual-same-as-auto
bus914 ·
can i use a type 3 auto irs subframe to convert a swing-axle type 3 to manual irs?
are the axles and cv's the same?
mackaymanx ·
The type 3 auto has a long and a short axle , about 12?mm longer/shorter than the standard type 1/3 axle.
I cv's are the same and I think the subframes were the same.
DallanMulley ·
The front mount is different.
[ Edited on 16-5-2006 by DallanMulley ]
seagull ·
if you go this way auto rear & you have the axles from the auto left over , please dont throw them away .I have a need for some
cheers seagull
