Aussieveedubbers · VW Circuit Racing
R5 NSW State Hillclimb 28.05.06 - Huntly Hill
https://forums.aussieveedubbers.com/threads/52417/r5-nsw-state-hillclimb-280506-huntly-hill
bat69 ·
For all those interested in having a bit of a look/see at a bit of motorsport. Round 5 of the NSW Hillclimb Championship is being run this Sunday 28.05.06 at Dapto by the WSCC.
So who is running or thinking of going down to watch because Ill see you there.
Sat practice? Might come and watch and make a weekend of it...
speedster356 ·
No Saturday practice. I havn't entered as yet, I'll try this week. I'll be there either way.
I'll be racing................... its a great event so everyone come down and watch !
Better get your entry in Pete!
fullnoise ·
Good luck. I drove up the track just for a sticky-beak last Friday. It's pretty steep and you sure as hell wouldn't need a navigator. Anyone with mild dementure should be able to remember the layout. It doesn't seem that tricky at 40kmph but at 3 times that speed with the undulations I bet it gets very interesting.
Greg's car sounded amazing on the video that I saw of last year's event. I heard he went over the finish line backwards a couple of years ago.
I'd love to come along but I'll be waving yokohama flags at Wakefield Park.
CYA
chequer57 ·
My memories and tips for Huntley are these.
Kept left after getting off the line "saves crossing the track twice... ie you want to be on the left before going into the fork".
First run of the day the top is still wet after the fork as the sun takes a while to dry it after the overnight dew.
Last run is a real bitch straight into the sun 🙅 (ouch)
Regards,
Ian
fullnoise ·
Let go of yourself Craig.
You might get blisters on your gear changing hand!
CYA CT
wombatone ·
It's not a very interesting drive up there. 1st, 2nd, 3rd. left, right, left, right. it all comes down to who got the most power. Rob Roy a bit the same down in VIC. well at lest in a low powered car anyway!
Yes and No, I have run slower times at that track when I had more HP than previous events. It is certainly like an uphill dyno, but there are a few tricks to the track which can give you at least a 1 sec advantage if you know what they are................I'm still trying to work them out !! Hopefully this Sunday I can get it all together, although the trees that are about a foot off the track sometimes bite at at 130kph............... its a lot easier when you are driving on a wide race track with nothing to hit!
wombatone ·
I ran a 42 or 45 when I was there last Sunday in my 1500cc rally car. Did so many events in the last 4 weeks (on the Ampol rerun) can't really remember! Will have to go look it up. What do you normally run and what class do you run in?
Improved production 1600-2000cc. My fastest time has been a 26.95sec run
[ Edited on 28-5-2006 by Craig Torrens ]
wombatone ·
It would make it a lot more interesting arriving at the corners in half the time. On the rerun I got to have a got at a few tracks around the place, my favourite would have to be Colengrove SA (spelling), Mt Cotton QLD and Morewell VIC. All interesting hill climbs. Is there a under 1600 Improved production?
under 1600, yep. This class is dominated by the Datsuns.
On 2moro...............come and watch
Directions:From north (on the freeway)
Take 2nd Dapto exit,right off exit ramp,at end of fowlers rd turn left onto Princess Hwy,approx 800m up the hill turn right at after the takeaway shop (Avondale rd), follow to the bottom of the mountain or listen for the sounds of high revs!
Hopefully it won't rain.
bat69 ·
C you 2morrow. Anyone coming down to watch?
sorry dude, want to work on my country buggy in time for for Valla
Good luck to youse both - especially bruddah! 😉
bat69 ·
A good day was had by everyone. All the VW's performed well with no hiccups. I went over half a second quicker then last year, Craig set a new record (Imp Pro 3J 1601-2000cc), Peter GUMLEY won and the FVee's went well also.
[ Edited on 29/5/2006 by bat69 ]
bat69 ·
wombatone wrote:Is there a under 1600 Improved production?
Yes. The record for this event is a Datsun 1200 with a time of 29.01
Was a great day.................another well run event by the Wollongong Sporting Car Club, so thanks to Chris Frazer (amazeer) and the team👍
amazeer ·
Thanks Craig.
Despite being 100% biased I am the first to admit that Huntley is no Bathurst and it is priced accordingly. It still irks me (though I am sure no offence is meant, and no long term offence is taken) that people think its an easy track. There's always at least 1 car that goes home on a flatbed after utilising that kind of mindset.
Anything over 40 seconds is indeed very boring. I wasnt at the Ampol re run due to family commitments but I understand it was all slow. I did 44 seconds in my stock fastback one day and gave it away after 2 runs. In 1953 at the first Huntley hillclimb, an MG TC won it with a time of 53 seconds on 3 inch crossplies when the track was dirt. So you can see that these times are slow. Those that ran over a minute must have stopped for a drink at the fork.
I ran 34-35's in my n/a kombi and it was a blast. I ran a best of 29.05 in my turbo kombi and that was insane. Then 27's in my turbo fastback, and a 24 in Jeff unwins subaru notch with a rolling start. When you have enough grunt, you actually have to 'drive' around the first corner. I have actually missed the apex of the fork, and been unable to recover in time for the esses and had a big slide. For every second you take off in ET the track seems to get a foot narrower and the dips and humps grow 10%. Its definitely not easy as.
My method of a fast time is to start from the extreme right and stay there until well around the first left hander using the middle of the road as the apex. The inside of the corner is steeper in my view. Cut the fork as close to the edge as you can from the far left of the straight. No backing off despite how daunting that is. That allows you to go as straight as you can through the left kink over the hump.
From here madness sets into my method. I late brake and turn in harshly but not attempting to make the apex as it dips away and unsettles the car. Most accidents exiting the esses start here IMO. Hopefully I've lost a little rear end grip and started pointing right when the corner goes left. This is the mad part because I've lost speed to pull up to the finish line which is one of the steepest sections if not the steepest. If you listen to the person who holds the record up there and has won more titles than anyone, you should sacrifice speed into the right hander to make a faster exit on the left. It just doesnt work for me. Mind you... we dont have his 450hp.
Anyway, in Donna Pell style I always say I wont do it again but one year down the track dulls the pain and I do it all again. Will be the 3rd Sunday in May, whatever that is.
[ Edited on 30-5-2006 by amazeer ]
amazeer ·
Why werent you running Pete?
I think Jon should sell his car to me. He seems to break something everytime he takes it out.
amazeer wrote:Thanks Craig.
It's certainly more interesting than Bathurst, at Huntley the sides of the track have teeth, willing to bite at any time !!
Menangler ·
Craig,
You made the local WIN News on Tuesday night, looked good!!
Wow, which part of the track did they film?
speedster356 ·
Craig they were at the start line. Didn't your agent contact you about the shoot?
amazeer ·
Dont get too excited, it was car #53. They shot from the start line only, and only 30 seconds worth. Lucky to get that because of the little drama early in the day. The camera couldnt hang around. I think there was only a glimpse of the Abbot beetle, the Curran Torana and Bobs fluoro mini.
bat69 ·
The one run they film of the beetle (dad driving) and the coil $hits itself on the start line and it was running like a bag of....Oh well.
At least a VW made the news. Ill be seeing dad on the w/e so if you want Craig I can arrange an autograph for you. I might be able to put you onto his agent..lol
BTW. Thanks Chris for an excellent event. I had a ball driving flat out up that hill. How is the young chap in the escort?
[ Edited on 1/6/2006 by bat69 ]
Good exposure for the Club and Huntley Hillclimb.
Pete your sacked:repuke.......you're no longer the manager for the champ! 😀
speedster356 ·
Hey I'm getting a job with John.......a rising star.:P
amazeer ·
The 'young' chap is OK. He was put in an induced coma on sunday night and brought out of it on tuesday night. Still in hospital but sitting up talking. Doesnt remember anything about what happened, perhaps not surprising. Dont think we will see him racing for a while but he will most likely be OK.
He is a lucky guy, if it happened on Saturday or Monday he would probably not be with us anymore. When the gods of speed came knocking on his door, he happened to be 2 metres away from an ambulance.
bat69 wrote:I had a ball driving flat out up that hill.
Even with your dementia :kiss
hypo-vw ·
hey amazeer , did anyone knock off my record for the 2 litre to 3litre sports sedans of 24.45 secs . that I set back in 2003 with my 2842cc normally aspirated 62' beetle .
amazeer ·
not even close. Arthur Hollins cortina (1600 turbo?) won it with 27.76
results -> http://wscc.org.au/2006.XLS
Had a clubbie yesterday. Weather cleared for the day. Only got 20 entries, 2 heavy stacks, 2 mechanically broken cars (local towies had a good day, one was heading up to Manly)...
Matt James LJ hit the embankment on the right 10 metres up from the finish and did some right front damage. The bigger one was the typical Huntley stack coming out of esses. Right foot in the dirt. Charlie Borg in the Honda Mini S/S drove up the bank and flipped it over. Heavy front end damage, broken rear susp, too much panel damage to mention.
I have to admit though, it was the worst run event that I've ever had my name on. Late start, unnecessary delays, running order was chaos, people running with both sides of grid... but still 9 runs before 4pm. Glad it's all over.
Graeme Syphers came down for a look, happy to have a reco pump in him despite having a lot of chest pain.... as you would after one of those ops where they rip your chest apart with a car-o-line
[ Edited on 16-7-2006 by amazeer ]
Bugger, I would have come down..............any chance of being on a entry mailing list? Or maybe you should just send me a club membership !!!
amazeer ·
easy to join the mailing list.
send blank email to events@wscc.org.au with subscribe in the subject.
2 left for the year, september 25 and november 5.
September is booked in as part of Nissan and Southern Sporting club's championships so will be a busy day.
Porsche is booked in for November, possibly MG club as well.
They dont have exclusive rights though.
[ Edited on 17-7-2006 by amazeer ]
