im planning on using expanding foam, but if anyone has a better idea...
david ·
put up with the noise ,should i say sweet purr of your kombi
david
kombi_kid ·
doing it cause im puttin in a big stereo and want to hold the noise!
rhys
Andy ·
Umm Rhys,
Sound proofing or insulation is achieved by the material absobing the sound, so won't 'hold the noise'.
Anyway, check out one persons view http://www.bulley-hewlett.com/VWindex/
I have used a combination of a glass matting (similar to to pink bats) for heat/cold insulation with an overlay of a sound absorbing material. Both are un affected by mosture and are non flamable. It is a good idea to wrap the glass fiber in plastic to stop them absorbing moisture and rusting out your panels though.
I havn't finished installing it all yet, but seems to work very well.
The stuff I got was pretty expensive though.
Andy
jboy82 ·
Umm ,
I think what Rhys means is he wants to hear big basses, not his bangin' boxer. 😀
I've done the same with my 68 bug.
I used the tar/rubber mats and then a triple felt layer material. It's much better than before but you can still hear the motor(when the sub is off, mind you) because I haven't insulated the engine/gearbox side of the rear floor area.
If you put insulation where there are no water/air channels or any direct contact with the outside, you shouldnt have many rust problems(if your car is not rusting there already).
Josh
kombi_kid ·
hey
same link as cols thanks anyway
where do people get ALL there sound proofing gear from??? just so i can go and talk to a supplier maybe!!!
rhys
[Edited on 13-4-2003 by kombi_kid]
azz ·
Ive just done this to my van in the last month or so
I got some 'seam sealer' from a body works supply shop and painted/spread this stuff on a very well prepared floor pan of the van ( the van was guttered )and I also went right up the slopey bit where the back seats sits up against. This stuff will stop any water getting onto the tray beneath and it will also work as a sound proofer. I removed all my wall panels and used a cavity wax everywhere and after it had dried I put soundproofing bats in the walls and then sprayed a glue all over them and the metal struts or whatever they are called and covered it all with clear plastic sealing the entire area from moisture and then I replaced the panel
So did it work??? against temperature? yes it did!!
against noise?? very very slightly 🙂
kombi_kid ·
yer i think ill go with so of that sound deadening paint first the the bats then the plastic!!!! i dont have any interior as its a panelvan so ill make some up!!!
thanks for all ur input guys i hope it works!!!
rhys
p.s. ill use lanolin in the seems!
Quickbug ·
The bats wont do much son!
Go to strathfield car radios or any of the larger car audio places and they can hook you up with some spray on, or paint on sound deadner.
If you really want to go hard core and arent worried about the extra weight you can also add sound deadening mats.
Be warned, neither are cheap in the slightest.
Give the bats a miss...
KruizinKombi ·
Fibreglass matts are designed to provide thermal insulation and work very well due to the amount of air trapped between the fibres, which prevents conduction/convection.
Sound deadening matts are much heavier, and as Quickbug said, quite expensive, but I think they're worth it if you want to hear the stereo without having to shout over it.
Andy ·
Ok,
I got all of my stuff from Insulation Supplies at Eagle Farm (Brissy) Ph 07 3268 7399
But you should be able to find someone closer.
The products were 25mm Tempmat (fibreglass) ~$350 for thermal insulation, enough to do the engine bay, full roof and behind all side panels.
Also 4mm Noisebar ~$150 for noise insulation, enough to do the engine bay, and behind all side panels.
A little over the top, but works well.
Andy
kombi_kid ·
all the sites ive seen have made me believe that the insulation bats are good>???? what are these mats called quick??? and do u have any info on cost?>??? i dont want to go out spending hundreds and hundreds of dollars if worse comes to worst ill live with it!!!and what are the fibreglass sheets called??
rhys
azz ·
The wife of the guy from the bulley-hewlet link obviously had him under the thumb!
He must have spent a fortune insulating that 'daily' for her!!!
*kombi-kid dont get 'insulation mats as they are too thick to go behind your panels-- get the sound insulation ones!!
I got mine from Bunnings Hardware for $40 and I used about one third of them. You can have the rest if you can get them to Sawtell
[Edited on 15-4-2003 by azz]
kombi_kid ·
so its just called sound proofing mats??? and what about sound deadener paint is that just a waste of time????
rhys
Adam_C ·
the body deadener paint is just a thick Tar like paint isnt it ?
i have an industrial tar paint called Orminoid, my dads pumbing shop sells it will this be good? this plus some type of foam (for heat insulation)? possibly this type of stuff painted on layers of foam sandwiched together?
where can i get that felt stuff . . . but not from jaycar, same without the vinyl backing?
[Edited on 16-9-2003 by Adam_C]
I believe the sound deadener foam spray is much better than what VW used over 30 years ago... I have sprayed it everywhere in My beetle but I had fish oiled everywhere before that.... I have some sticky bitumen-silver sound deadener sheets but they are much too heavy to use... I have also glued 20mm thick foam matting on all flat surfaces including the roof, to help stop the noise & heat transfer... I used the coloured foam mats approx 5 ft long used for camping beds etc. approx $20..
kombi_kid ·
wont that effectively hold in moisture lee??
rhys
KOM123 ·
Adam_C wrote:how is the insulation holding up KOM123?
Everything's holding up fine so far 🙂
Not sure what you mean by felt stuff though (if your question was directed at me?).
oval TOFU ·
68AutoBug wrote:I believe the sound deadener foam spray is much better than what VW used over 30 years ago... I have sprayed it everywhere in My beetle but I had fish oiled everywhere before that.... I have some sticky bitumen-silver sound deadener sheets but they are much too heavy to use... I have also glued 20mm thick foam matting on all flat surfaces including the roof, to help stop the noise & heat transfer... I used the coloured foam mats approx 5 ft long used for camping beds etc. approx $20..
Hey Auto
Is that foam sond insulation the multi coloured-looks-a-bit-like-carpet-underlay stuff? Whats the best way to adhere it to metal surfaces?
Adam_C ·
goto your local clarks and get some REALLY dense foam at bout 10-20mm and use paint on contact adhesice (easier to controll than the sprays) .... should stick REAL good..... drop into your local plumbing store and pick up a 1ltr can of orminoid or bitmuen paint and use that . . . i reckon itll be cheaper and better than the sound deadener paint.... use thinners or petrol if its a bit thick.... well thats wat i plan on doing for the beetle these holidays
You can buy it in green or blue usually rolled up at Big W etc and the cheap shops... I just used Selleys "fix all" which sticks just about anything to anything.... I have used contact cement before... without any hassles. I have completely covered My roof and side panels with this foam... in the doors, I have sprayed fish oil over it after it was dry.. just to make sure it doesn't hold moisture... I haven't tested it to see if it holds moisture or not.. I think the water will just roll off it..
I have also sprayed under the guards with underbody spray to stop stone chips and noise.... Lee
kombi_kid ·
do u reacon putting something over the foam that deters water would work such as a wax or lanolin or fish oil?
rhys
Adam_C ·
im pretty sure that my foam will get covered with some bitumen paint to stop the water geting into it and allowind it to be heavier therefore creating less chance of resonance...... if i insulate for heat with the glass bats ill use some plastic, glue and tape
chances are the high density foam won't get wet anyway.. I started it right at the top of the door panel and took it down about 3/4 of the way towards the bottom, as the glass goes very close to the outer door skin about there.. so if it does get water on it, it will just run down to the bottom of the door... You could spray it with rubberised stone guard or sound deadener.. I'm not sure what bitumen paint would do to the foam !!
Just fish oil everything.. its the best rust proofer... Lee
