Parts needed and some bits for sale
https://forums.aussieveedubbers.com/threads/52664/parts-needed-and-some-bits-for-sale
62ragtop ·
Hi Guys!
There are bits and pieces i need for my bug, any info appreciated:
-62 bug driver side 1/4 window in good nic
-Anyone know where to get the speedo face done in white for a 62 bug?
-front headlight jail bar style for 62 beetle
one last thing is anyone has a type 4 engine for sale? Thinking of changing to type 4 engine, preferbly 2 lt at least. What is the power like? Torque, bhp? Any pro and cons vs type 1? What mod do i have to do to fit it in my bug?
Thanks!
[ Edited on 29-5-2006 by 62ragtop ]
barls ·
i run a t4 in my bug and the power difference is huge im talking it cruises better, try reading das' thread on the mods needed. i get better ecconomy out of the t4 than the t1
62ragtop ·
Thanks Barls,
Where is Das's thread? What size is your motor?
barls ·
mine was the stock 2L but is now a modified 2L ie stock but mild cam. here is das' thead
http://forums.aussieveedubbers.com/viewtopic.php?tid=21201
be warned its long
62ragtop ·
Some small bits that i don't use anymore, anyone wants it? Make me an offer. John, melbourne, 0403368755 better do so before getting all the warnings......
[ Edited on 30-5-2006 by 62ragtop ]
62ragtop ·
And this....
LUFTMEISTER ·
interested in rocker armassembly. do you have both sides or just one?
hellbugged ·
yeah i like those rockers too, ya got u2u
ruckus ·
First dibs on the Jail bars. Can you please post a pic. How much do you want for them?
ragtopp ·
Are you hunting the speedster grills for your headlights or do you have some for sale? If you are hunting some ive got some, brand new.
cab1303 ·
like the firewall, you have u2u
62ragtop ·
DUBB61, i have both side of the rockers, sorry only took one side of the picture. Make me an offer.
Ruckus, i want a pair, not that i have a pair for sale. Sorry to dissapoint you mate.
ragtopp, let me know how much you want for a pair, U2U me.
cab1303, did not receive you u2u mate.
62ragtop ·
More items......
Flat 4 shifter and an as new Stewart Warner boost meter 60PSI max.
VWFOOL ·
how much for the shifter?
how much for that oil breather thing, first pic?
[ Edited on 30-5-2006 by VWFOOL ]
62ragtop ·
u2u you vwfool. One thing about the breather thing is the plastic cover has a small chip at the corner but it still seal properly.
Cheers!
VWFOOL ·
i hav no u2u, plz try again
cab1303 ·
U2u sent.
[ Edited on 31/5/2006 by cab1303 ]
62ragtop ·
u2u sent to vwfool.....hopefully this time it will arrive.....hehe:jesus
VWFOOL ·
right back at u
ruckus ·
2nd dibs on the shifter?
VWFOOL ·
still waiting on rpely to u2u
62ragtop ·
Sorry VWFOOL, shifter sold to EMPI which has the highest offer of all.
Cheers!
Anyon else interested in anything at all?
dumone, are you still interested in the rocker?
ragtopp, have you read my U2U? I am interested in the jailbar mate!
[ Edited on 3-6-2006 by 62ragtop ]
62ragtop ·
bump!
62ragtop ·
another one....bump:bounce
Dasdubber ·
With regards to the type IV conversion - yes it is worthwhile in my opinion, but depends on what you are trying to achieve and how much money you want to spend. If you have a nice solid reliable 2L that you don't have to do anything to apart from convert it to upright cooling, then it is not that expensive (or difficult).
Once you start modifying the type IV block/crank/pistons/cylinders etc - then the cost can skyrocket.
You have a few options again for the upright conversion - originally I used the kit from:
www.sharpbuilt.com.au
I have now converted to the DTM shroud from:
www.type4store.com
Out of the two the DTM has undergone much more research and was much easier to fit (a lot less fiddling/grinding/modifying what is supposed to be a bolt in kit). But it worked out to be about double the cost.
Basically you'll need to run a 210 or 215mm type IV flywheel and clutch assembly, but will need to have a brass bushing machined into the flywheel to mate to the type I gearbox input shaft. You then obviously need the upright cooling kit and an exhaust which will fit under the beetle rear apron. I suggest go and do some reading at:
www.shoptalkforums.com in the type4rum and aircooledtechnology forum - that will give you a heap of things to think about.
Alan
See here for my full resto details including sections on the engine:
http://www.manxgallery.org/gallery/album95
barls ·
here is mine its a little more indepth in the exhaust and heater setup than das' but not as big
http://forums.aussieveedubbers.com/viewtopic.php?tid=25214
62ragtop ·
Thanks guys for the advise, i think i will skip the heater part. Rod has given me a very good idea by using kombi's fan and route it to my external oil cooler to get heat. Very good idea but have to mout it somewhere......
How did you do yours Dashdubber?
barls, well done on your car mate. very inspirational as a lot of hardowrk has gone into it. All veedubers work hard to get their car together. Good stuff!
