Painting a car with rollers
https://forums.aussieveedubbers.com/threads/52733/painting-a-car-with-rollers
stephenianjames ·
Hey guys,
I was browing a Mini forum and someone posted a link to this article on painting a car with rust paint using foam rollers (go down to about the 9th post of so by '69chargeryeehah' for the relevant topic).
Seems an interesting method of painting, and definitely good for someone without all the proper gear and no money, but obviously wont chieve as good a finish as a properly sprayed car.
One of the problems I can see with this is that the paint they refer to isn't available here...do you think one of the locally available rust paints would be OK (will need to have a squiz at the article to know what I'm talking about).
I have bought some sample pots of White Knight Rust Guard to test on an old panel. The colour range of these paints is limited but if you like any of the colours it might be an option.
Any thoughts on the article would be appreciated.
KOM123 ·
This is the thread:
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=2331682&page=0&fpart=1&vc=1
stephenianjames ·
Geez I'm a dope..I thought I posted a link to the article.
Thanks for posting it KOM123...I don't know how you managed to find the right one!
Rollers like in this article.
http://forums.aussieveedubbers.com/viewtopic.php?tid=17341
stephenianjames ·
It's hard to see in the pic, but is the roller you refer to a foam one? The ones mentioned in the article are high density foam rollers (quite hard with very small air holes)
Mmmmmm yesssss it is foam. I would say it is dense compared to a carwash sponge. They specifically have ball shaped ends to help eliminate lines of material/ product buildup. Available from professional automotive paint suppliers. Designed for the foam insert to be chucked after each use. A PPG or Spies Hecker paint supplier should have them as it is in their range of products.
KOM123 ·
stephenianjames wrote:Geez I'm a dope..I thought I posted a link to the article.
I was pretty sure I knew which forum you were talking about!
stephenianjames ·
nice one...whats your username on ausmini mate?
KOM123 ·
The username was Curious from ages ago when I was first looking into getting a Mini. I don't post there anymore (but I still like to browse now and then) as I don't have the Clubby now :cry
Once number three came along, the family of five just didn't fit! Didn't want to sell it but it justed ended up being another insurance and rego to pay, car to maintain, and we weren't getting as much use out of it.
On the bright side, at least the fund went towards getting our Bus!
[ Edited on 31-5-2006 by KOM123 ]
Paddo ·
So how about some pics of this rustproof roll on top coat paint.....sounds too good to be true.
stephenianjames ·
Have a look at the link to the thread...there is talk about it and some links to pics of the various paint jobs. I agree though, does sound too good to be true but alot of the guys seem to be praising the idea.
Warrenm ·
Helbus wrote:Mmmmmm yesssss it is foam. I would say it is dense compared to a carwash sponge. They specifically have ball shaped ends to help eliminate lines of material/ product buildup. Available from professional automotive paint suppliers. Designed for the foam insert to be chucked after each use. A PPG or Spies Hecker paint supplier should have them as it is in their range of products.
My local Spies Hecker shop said no such thing at first and then said they used to have the rollers but stopped stocking a couple of years ago- any ideas?
Paddo ·
i am warming to it Jamez, maybe a gunmetal grey🙂:beer
Warrenm ·
PPG have the rollers-packs of ten plus handle and tray.
Thought I may try it on 72 Van to see what it looks like but where would you get paint such as Rustoleum
Only brushable/roller paint seems to be ag paint for farm equipment.
[ Edited on 3-7-2006 by Warrenm ]
The roller I am using in the picture is a PPG roller. I used it to apply the PPG primer/ filler. Not intended for use with topcoat paint.
matara ·
Pretty poor pictures (they were put up there in 1996 in internet infancy), but here is a bug I painted with a roller.
Looks good from 10 yards away. I would suggest white is the best colour to do, but you need to do plenty of T-cutting and Farecla G3 to get it flat.
I wouldn't recommend it on a car you want to restore properly later since getting enamel paint off will be a drama.
http://www.geocities.com/matara.geo/bmk208h/vw1200.html
[ Edited on 3-7-2006 by matara ]
aussiebaja ·
looks good ,ive used rollers, u should be able to get them anywhere virtually ,i just done my ski boat with rollers and it came up good ,but you have to be a lot more careful when applying so it comes out even and doesnt streak,good luck
