Hey guyz,
When i brake to a stop relatively quickly (alot of a brake pressure) and clutch in i get a sorta groan/squeek from the front end of my bay window kombi. Have lubed the front end frequently using moly grease.... any ideas on what might be causing this groaning/squeeking noise?
type3lover ·
Hey 76 Camper.
Mine squeaks and groans in the rain so is probably a bush in need of replacing but haven't really bothered to check.
Does the squeak in your bus alter with bumps or brake pressure? If it only happens when braking hard and assuming everything is tight and greased then its sounds like it's coming from the brakes.
T
76camper ·
over bumps i get a little bit of a squeek... not sure if its from my bull bar or front end tho. I will try and get some1 2 bounce on the front end while i try and locate the squeek... Just wondering if it might have been a common thing but obviously not 😢
