Aussieveedubbers 路 Tech Talk
rack & pinion
https://forums.aussieveedubbers.com/threads/52813/rack-pinion
sub60 路
Just wondering if anybody has grafted a rack and pinion set up on to a ball joint front end and if so what was the donor unit,CHEERS
71superbug 路
from what i remember i think there was a discussion somewhere about using the Rack and pinion from a CAMIRA.
not sure if this was for ball joint or strut front end though.
but in memory this was the only reasonable option mentioned in the discussion.
Vforce do a rack and pinion with a 1.1:1 ratio if you want to race 馃榾
Anthony
sub60 路
Thanks Anthony will look at that option CHEERS
BiX 路
try the tech mods section, and also i think wes ended up doing a 3d models to see how much bump steer would occur
71superbug 路
if you are going to be driving this on the street i would probably reccoment not using the one from vforce..simply because of its ratio.
Anthony
seagull 路
I am looking at fitting my subaru unit from the front cut on mike , I think you would do the same , neil
