Fitting turbo coolers on Subaru motors
https://forums.aussieveedubbers.com/threads/52924/fitting-turbo-coolers-on-subaru-motors
seagull ·
I plan to fit a water to air ( stock RS liberty / legacy ) cooler to my ride .
what have you guys fitted ?
71EJVan ·
Exactly that. WAIC+Radiator+Pump=$200 from SSS. Make sure you get the turbo to WAIC pipe as well as the A2A one is a little different.
Brendan
pete wood ·
200 bucks? that's great value! 👍
boof2332 ·
Try and get the stock pump as it increases flow when on boost.
My air to air on the trip to nelson bay did not get above 10 degrees....it has gone into negatives early on a damp morning. I have the fans off always and no water spray hooked up at present. Must be my special intales and sealed box. Maybe its the easy spooling turbo and the fact that there is alot less heat generated as the car is light and 2wd.
Matt
