Just picked up some nice new VW brochures from VWA's head office in Sydney. Interesting to compare the current Golf GTi with the New Beetle Turbo, as sold in Australia.
They both have the same engine - 81mm bore, 86.4mm stroke, 1781cc four-cylinder with 9.5:1 compression and turbocharger. 110kW at 5700 rpm, 210 Nm at 1750 rpm. The only diffference is that the New Beetle has a 120amp alternator compared with the Golf's 90 amp. Like all new VWs, they both require 95 RON premium unleaded.
Considering only the manual transmission models, both have the same 5-speed gearbox with identical ratios. 3.300 for 1st, 1.944 on 2nd, 1.308 on 3rd, 1.029 on 4th and 0.837 on 5th. The diffs are different - the New Beetle's is 3.938, while the Golf's is taller at 3.684.
The Golf is 68mm longer and 11mm wider than the New Beetle, but 59mm lower. The Golf's wheelbase is 3mm bigger, and its front track is 5mm wider. Rear track is the same on both. The Golf has an unladen weight of 1256kg, which is 20kg lighter than the New Beetle.
The New Beetle has 70mm more front headroom, and amazingly, 64mm more rear legroom than the Golf. The Golf has 3mm more front legroom, and 26mm more rear headroom. The Golf's boot is more than twice as big as the New Beetle's.
As for performance, the Golf takes 8.5 seconds for 0-100 km/h. The New Beetle is slower, 9.0 seconds. The Golf also has a higher top speed - 216 km/h, compared with 203 km/h for the New Beetle. And the Golf is more economical - 8.3 L/100km City Cycle to the New Beetle's 8.9. The Golf does 5.7 on the Hwy, compared with the New Beetle's 5.9.
And the Golf is cheaper too - GTI 1.8T 5-speed is $41,946 on-road. The New Beetle Turbo 5spd is $42,976.
The colours and cloths are totally different, with the Golf coming from Germany and the New Beetle from Mexico. The Golf's are more conservative - no bright yellow or green paint colours that the New Beetle has, but the GTi can have black/red or black/blue cloth upholstery.
Phil74Camper ·
